Tractor Talk Discussion Forum
8n fluids
lee yeager
12-30-2006 16:06:29
I am new to the tractor thing and am about to replace my pto shaft due to it being bent. The manuals I have clearly show that it requires 5 gallons, but it never says "of what". Anyone out there that knows. Thanks
Pooh Bear
12-30-2006 17:54:12
 Re: 8n fluids in reply to lee yeager, 12-30-2006 16:06:29
You need 90wt gear oil. with GL-1 specs.
Must be GL-1, not GL-5.
I got a gallon from NAPA for about $8.
Pooh Bear
GL-1 90w Mineral Oil from NAPA 5 gallons
Napa Part# 65-205 1 gallon
Napa Part# 65-201
rlyeager
12-30-2006 18:25:12
 Re: 8n fluids in reply to Pooh Bear, 12-30-2006 17:54:12
thanks a lot. that will really make a difference.
Pooh Bear
12-30-2006 19:28:17
 Re: 8n fluids in reply to rlyeager, 12-30-2006 18:25:12
For some reason the forum software
screws up the layout of my posts.
Just to make sure that is read properly
I am posting it again.
5 gallons Napa Part# 65-205
1 gallon Napa Part# 65-201
I called the local store and they looked up the part number.
They didn't have it in stock.
But they said that I could drive out to
the main store/warehouse and buy it.
I was going by there that day so I stopped and got it.
Pooh Bear
12-30-2006 19:30:14
 Re: 8n fluids in reply to Pooh Bear, 12-30-2006 19:28:17
Forum screwed up the layout of my post again.
Looks fine on preview.
But when I go back to read it, all the line breaks are gone.
It looks like one long paragraph.
Pooh Bear
old
12-30-2006 16:09:22
You need what is called GL-1. If you use other things it can cause problems from what I have heard.
Ken L.
12-31-2006 07:23:16
 Re: 8n fluids in reply to old, 12-30-2006 16:09:22
About five years ago when I changed the oil in mine, the charts at the N.H.(Ford) dealer said to use their 134 oil. It"s a lot thinner than the 90 and works excellent in cold weather. In cold weather, the 90 will be like tar and the hyd system will be very slow if it works at all.
