Tractor Talk Discussion Forum
Clark Forklift
Kelly Campbell
12-15-2006 18:28:12
Ok I know its a little OT but it does have engine, propane, older fork truck, replaced the plugs, wires, rotary button, cap. It would run but with out much power, then something happend and now it won't start....Any ideas???? I've never worked on a Propane Engine before.
THanks
KElly
davpal
12-15-2006 22:11:17
 Re: Clark Forklift in reply to Kelly Campbell, 12-15-2006 18:28:12
This might sound obvious but did it run out of propane? I have done it before. I also had the coil go bad on mine one time and it would not start. It took me a while to track that one down.
jon in il
12-15-2006 19:58:24
first thing is the spark is good. Then fuel remove the hose from the carb to the reg for fuel pressure. If there is any pressure the reg is proble bad. If the reg is bad don't rebuild replace. If you have any more question you can email me at Jmolson@mchsi.com I work for a forklift company as a tech.
Handyman
12-15-2006 19:47:51
You probably need to have your carb and regulator rebuilt
