Tractor Talk Discussion Forum
case tractor model #?
sbeck
12-11-2006 00:55:10
I have a case tractor Propane-with an eagle hitch,wide front end that is out in front of the radiator,and the hand clutch is on the left side.Engine block casting is B4848
The serial number plate is missing.how can I identify the year and model?
Tom Railsback
12-11-2006 06:35:06
 Re: case tractor model #? in reply to sbeck, 12-11-2006 00:55:10
From your description, I'm guessing it's a DC as they are the only model I know of that had the front axle ahead of the radiator and a hand clutch.
Look on the left side of the engine block where it bolts to the transmission case; the serial number should be stamped on the flange. (You might have to scrape a little paint.) When you find it post for DC Tom on the Case forum; he can give you a mini history.
