Tractor Talk Discussion Forum
1952 Farmall M stuck in gear
JBW
12-03-2006 19:43:23
We have a 1952 Farmall M - it's stuck in gear heading downhill on a fairly steep slope (in the middle of our driveway!)
Previously, I have been able to get a pry bar into the hole where the gear shift lever is and move it - but this time, it just won't budge.
It will start with the clutch, but won't drive or drift. Any ideas? Thanks.
Allan In NE
12-04-2006 01:50:27
 Re: 1952 Farmall M stuck in gear in reply to JBW, 12-03-2006 19:43:23
JB,
Put a jack under the drawbar and lift one side to take the pressure off. Then, align the forks.
Allan
JBW
12-04-2006 02:46:43
 Re: 1952 Farmall M stuck in gear in reply to Allan In NE, 12-04-2006 01:50:27
Thanks for the added idea - it's a long steep driveway and I know my husband is pondering how to safely pull it down or back up (it's longer going back up.) - Ann
Allan In NE
12-04-2006 02:57:47
 Re: 1952 Farmall M stuck in gear in reply to JBW, 12-04-2006 02:46:43
Tell him to be careful; don't want an accident here.
Is the driveway dry? Lock just the left brake and jack up the right side.
If the drive is ice covered, I'd just hook on to 'er and slowly drag it to level ground with the tires "sliding".
Either way, you have to get that gravity pressure off the transmission before it can be "unlocked".
Allan
Don L C
12-03-2006 20:26:50
IaGary has told you correctly, the problem and how t fix it..... the reason you cant move the gears is because the pressure on them, because of the down grade ..... .put some up hill pressure on the tractor so you can move the gears.....don
P.S. you might want to add some (1/8")weld to the bottom end of the shifter, grind it to shape.....
IaGary
12-03-2006 20:01:06
Hook something onto it and pull it up the hill a bit to get the pressure off the transmission.
Sounds like its in two gears to me.
Gary
IaGary
12-03-2006 20:06:18
 Re: 1952 Farmall M stuck in gear in reply to IaGary, 12-03-2006 20:01:06
Me again.And if it is in two gears the one you think is out of line is in gear the other way.
May need to move all three rails to center position.
Gary again
