Tractor Talk Discussion Forum
turning up the pump and the power!
spitz
10-27-2006 05:55:42
Wondering if you guys have ever turned up a diesel pump for more power? I have a cat 3306 engine with 300HP and would like to get it up to about 350-360. Any concerns?? These engines show up a lot in other equipment and I was wondering if they have more power in those tractors/ bulldozers/ trucks etc.
RodInNS
10-27-2006 14:16:53
 Re: turning up the pump and the power! in reply to spitz, 10-27-2006 05:55:42
Yes... I've got some engines cranked up. Yes, someday I will pay for that feature. Would I turn up a 3306-300? NO. It's spec'd at about it's top rating right there, so anything beyond that and you could likely expect to see problems. If it's worth melting a piston, then go for it. You'll get more power, but it's going to cost you in engine life. If you did take it to 350, then I would not consider that to be anything more than an intermittent rating. You wouldn't want to lug that engine hard for long. It's also going to cost you fuel as there's going to be a lot more going up the stack...
Rod
