Tractor Talk Discussion Forum
electric fence revisited
Farmer in the D
10-24-2006 06:45:34
Well, the fence is up. Only took time to drive one ten foot galvanized ground rod for trial. Did a final check and turned it on. Only had to wait 5 minutes for test. The critter that usually goes AWOL came to investigate and found out it won't be so easy to go. There is one side of my pasture the runs along side a road where a lot of local people walk. Some of these walkers like to stop, pet, and feed the critters at times. I don't care for the last part since I have no idea what they getting fed. Anyhow, I assume if someone decides to pet the critter that contacts the fence, it may have a dual purpose. Keeping the critters in and the walkers out. I might post signs along that side though. Just in case. The second loop of the pasture is to move them farther off the road during walking season and for rotational grazing. There is no fence at all there so I will rely on a poly tape after they learn and respect the wire. Judging from yesterday, that won't take long. Thanks for all the suggestions. I will probably do what Nathaniel suggested and run the second loop of the "8" off the same controller. I can always switch or disconnect the closer loop to go back to the far loop if need be, and only run one controller.
vally farm
10-24-2006 18:42:48
 Re: electric fence revisited in reply to Farmer in the Dells (WI) , 10-24-2006 06:45:34
Here in good ole N.Y. if you zap someone and the fence is NOT flagged with "authorized" signs on it, they can sue you for pain and suffering! Don"t worry that they had to trespass to get zapped, it"s your property, so they have all the legal rights! I"m not joking!!! All hot fences facing out should be marked. Welcome to America COMRAD!.....Mike
Gerald J.
10-24-2006 10:41:42
Electric fence suppliers carry signs that say "Electric Fence". Might be a good thing to add on the walker's side.
Gerald J.
nballen
10-24-2006 07:42:56
Well thanks! I (often) wonder if anything I throw out here is useful, or if I am just "talking" out my....
Anyway, I hope it works out for you. Not to cause a scare, but is there (could there be?) a liability issue if someone gets shocked by your fence, when they aren't expecting it? Maybe JohnT will have some good input?
I've only had livestock where theres not too many people around, and never adjoining a "public area", so I don't know how other folks will react to the electric fence. I just warn the immediate neighbors, and we get along great!
Nathaniel
