Tractor Talk Discussion Forum
hiway bridge height
Roy Suomi
10-12-2006 20:13:13
Does anyone out there know the minimum bridge clearance if it's not posted..I'm coaching a couple of new guys at the township garage so they can get their CDL..It's not in the CDL book and I remember missing it when I took my test some years ago..Man , if you " seasoned " drivers want a reality check , go take the test.. Thanks..
Roy Suomi
10-13-2006 13:50:03
 Re: hiway bridge height in reply to Roy Suomi, 10-12-2006 20:13:13
Thanks guys...Roy
Trkr
10-13-2006 12:09:29
States east of the Mississippi Rvr, 13'6".West of the river 14",except Ia,still 13'6".Nebraska 14'6'.
wayne from wi
10-13-2006 06:43:12
Bridge height is 13'6'' unless posted lower for a particular bridge. Some states will have theirs at 14'. But 13'6''is mandatory.
the tractor vet
10-13-2006 06:00:44
Here in the Buckeye bridge statiory hight is 13.6 or above anything lower must be posted as to it's hight but here it can vary from state to state best look it up for your state .
Oldmax
10-13-2006 04:57:49
In most States it is 14' on State Roads . Might be different in some states . You don't see many vans over 13' 6" . If power Co runs line a line across road it has to be at least 14' above road .
Christos
10-12-2006 22:51:49
If I remember correctly, if its an interstate standard highway...it should be at least 16-9. I know in Ohio most of the bridges on the freeways are being rehabbed to this height. It depends though.
CLW
10-12-2006 21:02:10
Call your state DOT.
504-1
10-12-2006 20:58:51
Depends on the state,most have a height limit of 13ft 6in. I have seen bridges posted from 7ft to 30ft.
