Tractor Talk Discussion Forum
JB Weld on exhaust components?
DAH
09-13-2006 07:25:23
I need to attach a muffler into a cast iron elbow on my JD LA. The muffler tube going into the cast iron elbow is 1.5" in diameter. I know brazing would be the best solution, but would JB Weld work? What are the limits when using JB Weld on exhaust manifolds / pipes / mufflers / etc?
Thanks....
Fred Martin
09-13-2006 10:20:38
 Re: JB Weld on exhaust components? in reply to DAH, 09-13-2006 07:25:23
What I used when the exhaust manifold started leaking on an old Ford tractor is furnace cement. You can get it at most decent hardware stores and theres a muffler patch available at parts stores in a small tube...but the hardware store sells it in a pint can for a much better price. Fred OH
Gerald J.
09-13-2006 09:55:28
Muffler repair products generally contain water glass and it stands up to exhaust heat. I think its sodium silicate. Makes up a water solution that cures hard and will stand heat. Its not as strong as brazing.
Gerald J.
shawnspeed3
09-13-2006 09:14:57
Most "High Tempature" epoxies start loosing their bond at 400 deg. F. most general epoxies will start de-laminating in the 180-250 deg. F range . Since most exaust systems close to the engine run in the 900-1500 F range any epoxy is out of it working range.Better stick to brazing/muffler clamps in this application. Shawn
old
09-13-2006 07:42:56
JB weld would just melt in that type of place, its not made for temps like that. They do make a stuff that works like JB that will worl for what you want but its also made for exhaust system
RustyFarmall
09-13-2006 08:22:24
 Re: JB Weld on exhaust components? in reply to old, 09-13-2006 07:42:56
Several years ago I tried using JB weld to secure an exhaust system on a riding lawn mower. It took all of about 10 seconds for the JB weld to melt and begin oozing out of the joints.
IH2444
09-13-2006 10:16:01
 Re: JB Weld on exhaust components? in reply to RustyFarmall, 09-13-2006 08:22:24
Yep, when I was a kid I tried using solder on a briggs exhaust. Just dripped out within 15 minutes of running :)
