Tractor Talk Discussion Forum
9N ford that is missing when under load
hmcorpman
06-16-2006 22:51:10
I have a 1940 9N ford that keeps missing when under a work load. It became realy noticable when using a brush hog. I have cleaned the carb and all the screens in the fuel line that I can find. Plugs and wires look good as far as I can tell. Any suggestion would be great. New to tractors but love these old fords.
hmcorpman
06-17-2006 20:17:12
 Re: 9N ford that is missing when under load in reply to hmcorpman, 06-16-2006 22:51:10
gentalmen, thank you. I will be replacing the plugs in the next day or so and check the wires at night. Not much into the bite of blue light. I will keep up informed of what happens.
old
06-17-2006 07:58:29
You can not look at plugs or plug wires and tell if they are good or bad. You can find bad plug wires if you fire it up in the dark, if there bad you will see a sort of blue spark jumpping all over the place. Or when its lite out you can just carefully grap one wire at a time but if you do it that way you will pay for it because it will ZAP the ---- out of you if there bad. I would replace the plugs and also probably the wires
Larry Mills
06-17-2006 06:57:55
Put in new plugs!!! ASAP - will run like a top
RustyFarmall
06-17-2006 04:30:26
Just for the fun of it, go ahead and install a brand new set of spark plugs. Quite often a plug that looks good is not.
hmcorpman
06-22-2006 18:33:22
 Re: 9N ford that is missing when under load in reply to RustyFarmall, 06-17-2006 04:30:26
Hey fella"s changed the plugs ran no different. Pulled the cap and rotor. Pretty much gone, I replaced that and through some new wires on it and running like a champ. Thanks for the help.
