Tractor Talk Discussion Forum
Hercules engine stuck vavle need help!!
sjh
05-20-2006 15:34:02
I have a hercules 6 cylinder(model jxb) and it has 2 stuck exaust valves. Is there any way to unstick them without taking the head off. Thanks
Scott
BLW
05-21-2006 09:40:53
 Re: Hercules engine stuck vavle need help!! in reply to sjh, 05-20-2006 15:34:02
rope works so does allen wrench etc. but that jxb- also the jxc and jxd is one of the easiest heads to get off and on-- then you can check for burnt valves??? gaskets are not hard to come by
mbs
05-20-2006 19:45:29
If you can get the engine to run, use the proven old time remedy and run some brake fluid through the carburetor air intake.Just a little at a time of you will kill the engine.Do it outside or keept the doors open.The brake fluid will produce tons of smoke.
Keith-OR
05-20-2006 19:26:43
sjh, awhile back some one on here posted same problem, they were given advice of getting a long piece of rope and stuff cylinder full then slowly turn engine over with hand crank or tapping starter repeatedly. You need to spray penetrating oil on the valve stem before you turn engine over.HTH
Seems like it was Tractor Vet that put this info out...not sure though
Keith & Shawn
MarkB_MI
05-21-2006 03:49:49
 Re: Hercules engine stuck vavle need help!! in reply to Keith-OR, 05-20-2006 19:26:43
The rope-in-the-spark-plug-hole trick works with overhead valve engines. If the Hercules is flathead, I don't think it will work.
Keith-OR
05-21-2006 11:45:42
 Re: Hercules engine stuck vavle need help!! in reply to MarkB_MI, 05-21-2006 03:49:49
MarkB, well I didn't know if it was flat head or over head, just put out info just incase. Never know what info someone might need. Anyway good afternoon out there. Seems like my girlfriend from MI said this morn it was raining in her area this morn.
Keith & Shawn
Larry from md
05-20-2006 16:20:52
If they are not stuck bad you can use an allen wrench through the sparkplug hole to push it down.Then turn engine over and if it sticks again squirt with oil and repet untill free.
old
05-20-2006 15:50:47
Maybe. You might try filling the cylinders with tranny fluid and also pour the exhaust manifold full of tranny fluid and let it sit a couple days. If you can get those 2 cylinders up about half way on the exhaust stroke so the intake valves are closed. That way the tranny fluid will stay on the valves and not drain out by way of the carb
