Tractor Talk Discussion Forum
Ford F 350 towing capacity
37 chief
02-09-2006 17:08:42
What would be the maxium trailer GVW my f 350 will be able to pull? I have a receiver hitch. Not a 5 th wheel hitch. Thanks Stan
Tim B from MA
02-10-2006 09:19:02
 Re: Ford F 350 towing capacity in reply to 37 chief, 02-09-2006 17:08:42
I believe my SRW F-350 crew gross combined vehicle weight rating (truck plus trailer plus everthing in them) is als0 20K (have not looked in a while).
But you also need to be aware of GVWR for the truck itself, and the rating for the tow hitch - see my reply above about another similar question.
John in WV
02-09-2006 17:38:42
An F350 duel wheel gcwr is 20,000 lbs with a five ton trailer.
A single wheel F350 is 18,000 lbs. with a five ton trailer.
Anything over 5 ton is illegal.
Look on your door panel and it will tell you what you can gross.
