Tractor Talk Discussion Forum
gasket sealant
J. Rand
02-07-2006 09:40:17
I"m restoring a JD 720D and have it completely apart. I have all the gaskets needed to put it back together, but I don"t know when to use sealant or when to just use the gasket. Are there any rules of thumb for this? The manual says use permatex 7 on one side of the head gasket, otherwise there is no mention of it. Thanks.
dougn
02-07-2006 17:44:31
 Re: gasket sealant in reply to J. Rand, 02-07-2006 09:40:17
I used 3m weatherstrip adhesive on one engine many years ago. When I pulled the engine down later I thought I would have to break the intake manifold and oil pan to remove them. Stuck doesn't describe it. Now I just use a little silicone.
REDJD
02-07-2006 21:43:15
 Re: gasket sealant in reply to dougn, 02-07-2006 17:44:31
You should only put the 3M on the part,oil pan, valve cover, water pump,ect. not on the block.
champspa
02-07-2006 16:53:42
Locktite gasket eliminator only seals between surfaces type 515 or 510 , 515 stays flexible
williamf
02-07-2006 13:01:07
Does anybody use shellac anymore?
Bob
02-07-2006 11:45:17
For many block and transmisson gaskets, Deere recommended smearing them with ordinary grease before installation.
Nowadays, restorers probably wouldn't like the dirt that would stick to the edges of the gaskets, and the stuff that would ooze out on their new paint!
Like the other poster said, if you use silicone sealer, just use the smallest amount that will seal the joint, as you don't want gobs of it inside the engine, where it will eventually swell up, fall off, and make it's way into the oiling system.
REDJD
02-07-2006 11:40:41
Go easy on the silicone, I have a engine in my shop now that had no oil pressure and when I tore it down I found out why.Someone had used silicone on the gaskets and the oil pump was stopped up with the stuff.I use 3M weather strip adhesive on all my engine parts and stick the gasket to the part such as an oil pan or valve cover ect. If you let it dry and don't use too much the gasket will stay in place when you put the part back on the engine.
Jubal Lee
02-07-2006 10:14:23
You will probably get opinions all across the spectrum on this one. Personally, I use silicone sealer, but sparingly with discretion, depending on the application. Sometimes it helps hold a gasket in place for assembly and a little bit of help in sealing off imperfections in the surfaces can't hurt. You just don't want to use enough to make a big mess and don't over tighten your bolts as the sealer will make the gasket squirt out from between whatever two surfaces you are mating. My $0.02 worth, which with a quarter, used to would have bought a cup of coffee!
Mike M
02-07-2006 10:59:12
 Re: gasket sealant in reply to Jubal Lee, 02-07-2006 10:14:23
I'm with you, and do the same. It really helps if you have to go back and take something apart too. There are alot of different types of silicone on the market. I have been using the ultra type with good results.
UncleTom
02-07-2006 14:50:14
 Re: gasket sealant in reply to Mike M, 02-07-2006 10:59:12
I agree with Red JD, 3m weather stripping compound will seal anything. I have never had to remove it though. It is great for rubber gaskets. Even works for putting plastic sides back on a pocket knife. It never came apart agian. My .02
