Tractor Talk Discussion Forum
Welding, upside down....
Billy NY
04-03-2006 18:54:31
What is the deal when you need to weld out of position, looking up at the work ? I can run 7018 all day long in position, looking down at the work, sometimes changing my amperage depending on what I am doing, steel thickness and the size of the electrode I am using. I will usually dial myself in on a piece of scrap prior to doing the actual work, and have really improved my weld profiles since I first started welding a few years ago. I ran a few passes this afternoon, and they really came out nice, don't do much except repairs and some fabricating on occasion, and have a good working knowlege on the procedures to make structural welds, but still an amateur.
On this F-600 I'm reinforcing the frame on, where it was lengthened, the top part of the C-channel, flange apparently was never welded, where the c-channel extension piece was added, although the vertical web was welded substantially, and the bottom flange was plated over the joint, where you can see it looking down. When I exposed the upper flange, by hacking through the dump body frame, I saw what looks like a crack,or a joint, so I ground it clean, "vee'd" out the area, made 2 passes in the "V", last one with the heat up at 140 amps, using 7018 5/16" dia., and one on either side of that, I burned through one spot, but built it up, ground flat and the last pass went over it. Good penetration, probably why I burned through a thin spot.
Looking under the flange from the inside you can still see what looks like a crack and I'm thinking a nice bead would really finish it off. I've just never been able to get a good profile working upside down. I'm thinking, keep the heat up and the puddle flat,it won't fall out like stalagtites or mites (which ever fits here LOL ) like what usually happens. Not sure and have never mastered this, I have no problem at all making a good convex fillet weld profile with 7018, in position, with this '00 Miller Trailblazer NT 251.
ebbsspeed
04-04-2006 10:51:55
 Re: Welding, upside down.... in reply to Billy NY, 04-03-2006 18:54:31
Not sure about the Ford F600, but on most larger trucks it is a NOT RECOMMENDED to weld on the horizontal sections of the frame, as they are tempered. Many of the frames have a sticker or even have the warning stamped in the metal. Any shop that specializes in lengthening truck frames does it by riveting or bolting, not welding.
Billy NY
04-04-2006 13:05:02
 Re: Welding, upside down.... in reply to ebbsspeed, 04-04-2006 10:51:55
I'm well aware of that, I knew mentioning a truck frame and referring to myself as an amatuer would cause a stir here LOL !!!
I've driven many trucks with these labels on them, we have a body and chassis shop, Howe Bros. in town that made their name from Howe-Coleman 4x4 conversions in the medium to heavy truck class, my neighbor was a mechanic there, now retired. They installed bodies, did the 4x4 conversions etc. He was a truck and heavy equipment mechanic for many years, used to work with him at one outfit, he's a good source of information.
I've spent a lot of time around trucks, have a clean CDL for 18 years and held the state equivalent Class 1 prior to that, I know the importance of safety and trucks, have worked for enough companies as a driver to be concerned. I agree, a truck frame is nothing to fool with.
This truck is a 1964, I do not believe it has heat treated steel frame rails, the lengthening that was done is not your typical double frame arrangement, sleeved on the inside, but it has held for 42 years. The vertical weld shows no signs of fracture or fatigue. What I am doing is completing the weld on top, that apparently was not done on 2 of the joints, at the top flange, the other 2 were done and are in good shape. The bottom flange was plated off, the rust from those plates heaved them up, the welds were poor anyways, but the frame steel did not corrode, thickness is still there and no signs of fatigue, these plates on the bottom will be replaced.
Figuring that the existing worked for all those years and the fact that I drove this truck 800 miles with a car on the back, I think the methods ( which I don't necessarily agree with )used will be fine for my application, hay, sawdust, compost etc. It will never haul it's max. load, and not go off road with any heavy loads on, twisting and contorting, which is really stressful on a frame. It will get retired and I'll probably complete the restoration on it as a hobby,using it as a secondary truck if needed.
Irv (Ia)
04-04-2006 10:18:55
Don't you mean 5/32 rod you were using? It would take 300 amps to even get a 5/16 rod to strike an arc!!. I agree that 1/8 would be better-that's a lot of metal to hold up there.
ElmTree893@aol.com
04-04-2006 13:13:47
 Re: Welding, upside down.... in reply to Irv (Ia), 04-04-2006 10:18:55
Yes, 5/32" is the correct size,I'm using. I'm mixing up 16ths and 32nds again. I did that when I bought the 10lb. can, asking for 5/16" in a 10lb. can, the guy said, "you mean a 50 lb. can", and I had to correct myself.
I have some 3/8" plate to weld and don't normally need any large diameter rod, so I figured the next size up from 1/8" would get used up here.
T_Bone
04-04-2006 06:40:47
Hi Billy,
Wow, learning to weld on a truck frame is not the correct place to learn welding. Seriously, consider taking a Vo-tec welding course before you hurt someone.
Welding overhead is just like welding in the flat position, no difference. Why your having problems is caused by several problems. Use a 1/8" electrode and the correct amperage and more important the use the correct arc length.
Using the 5/16" electrode is causing you to turn down the amps to keep from buring a hole. That in turn makes you use a very long arc length thus apply more heat to the Haz thus why all the dingle berries keep falling on you.
In all my writings on the tool forum about welding, you'll notice I always harp on using the correct arc length, ie; being very tight to the base metal. This allows you to control the molten puddle using the correct welding amps without having dingle berries (large ones) fall on you.
You might want to spend some time reading the tool forum archives as there's been many threads written on welding.
T_Bone
Billy NY
04-04-2006 15:55:58
 Re: Welding, upside down.... in reply to T_Bone, 04-04-2006 06:40:47
I agree, a truck frame is not the place to teach ones self how to weld, there is no doubt about that.
I think I've made myself appear more of a novice than not, trust me, I've got some skill and ability, but within limitations, that I would not exceed. The work that I am doing is in no way going to get anyone hurt, the frame will be stronger than it was, and I don't agree with the methods used by whoever did this work originally, but it has held with no stress or fatigue, even after the bottom plates popped from expansion of rust.
The main vertical welds are the strength on this extension piece in the middle of the frame, and with the bottom flange plates re-done, ( 3 of 4 were heaved from corrosion, the old poorly done welds failed, the frame did not rust here except on the surface) the vertical welds in-tact, top flange joint fillet welded, and plated over and welded, same joint also gets a 3/8" x 3" angle through bolted spanning over the existing vertical joint, for the dump body mid mount, I'd have to think it will be very strong. If one were to grossly overload the truck and abuse it off road, yes I'd expect a failure, but not with careful or normal use. Ironically the dealer who sold me the truck made no mention of this, I'd have not bought it, loaded my car on it and made the journey home, as is, it would have failed long ago, I think it's been caught in plenty of time and the remedial work will eliminate any worry about it.
I won't ramble on about my experience and skill level, but I do have an extensive background in the building construction industry on some very large projects, and considerable experience with the associated field welding common to the industry, that has been very helpful outside of work, but also agree the vocational welding course would be highly beneficial to anyone needing to learn, including myself, I will keep an eye out for a course locally, even if I breeze through it, there is always something to learn and I'm no expert. It will however expose any bad habits and other practices that may be incorrect, will be well worhwhile.
I have spent considerable time while building mock-ups at various testing labs, doing quite a bit of welding, with experienced and certified welders giving advice, was a real good opportunity to take advantage of, glad I did, was very helpful. I was also senior project manager and a field superintendent for a curtainwall contractor, I used to have a lot of trades to keep track of, and all kinds of structural welds to place, have inspected etc., the experience has been helpful aside from work.
I was thinking that the arc length was the key to this, I know what happens when you get too close, ove too slow, use too much heat, or too far away, either burn through or it starts popping, and you lose the arc, then it sticks on the re-strike. Your work gets covered with slag and the weld becomes porous, you can make a mess quickly, I've done that as I think most people have when first starting out, it is part of the learning curve. I will use the same amperage as what gives me a good weld on the flat and 1/8" 7018 electrode, keeping tight to the base metal. I can test this on scrap and dial in from there mocking the position I need to do it in. I agree, the arc distance is very important, it is obvious when you observe your work, how things are affected, it takes some time to be able to maintain that distance correctly and continously, otherwise snap, pop, crack and you are stuck. The 7018 likes the heat, turn it down too low and this happens I've noticed. I use a dark, shade 11 lense, so it can be hard to see sometimes, which also plays a role here too, but I like to protect my eyes with as dark a lense as I can get away with. I don't need the 5/32" electrode for the underside of the flange, the flange is 1/4" thick, and the top came out very nice, I just need to run a neat, well formed weld to fill in the 2 1/2" joint from underneath, it will look good aesthetically to an inspector, but more importantly will also provide more strength.
These 2 top flange joints were open all these years, not sure why they stopped the weld there, on just these 2 joints, the other side of the piece added, the weld was completed from top to bottom including both flanges. Once done, this frame will be stronger than it was, if I had any doubt I'd have a shop do it. I had the truck looked over for commercial inspection by a reputable truck/diesel engine repair shop I've known for years, we went over the repairs needed in detail, agreeing that the work I'm doing will be fine, and he's strictly by the book. I could add diagonal fish plates to the web, but see no need to do so. I will take a look into the previous threads, I've read many of them over the years, one of the great things about this site is the archives and access to them. Do appreciate everyones advice, thanks again !
T_Bone
04-05-2006 09:20:57
 Re: Welding, upside down.... in reply to Billy NY, 04-04-2006 15:55:58
Hi Bill,
You need not take eveything I say in my post as being personally directed at you. I try to respond to threads for everyone's benefit, to which the Vo-Tech comment is more directed to very inexperienced weldors. I figure the more experienced weldors will just ignore my comments that doesn't apply to them.
Something to consider with beams in tandum is both beams would need the same repair treatment so the design flex stays in balance. By beefing up one side of a tandum beam then this becomes less flexable and will cause the opposite beam to stress more than it's design spec thus will also split after a short time.
Once a beam fatiques to the point that it cracks, a gusset 12" on either side of the crack center line is usually what is required to make the repair. I have also seen where 6" works well depending on the location. A person needs to be careful not to tie welds or plating together from horizontal flange to the vertical web.
If your sticking your electrode while trying to keep a short arc length then your most likely about 20amps to cold. With 1/8 7018 rod you should be about 130amps or so for the average weldor. I like 150amps on 1/4" plus material. Travel speed will control small amperage speads, 10 to 15 amps. Yes there are a few joints that I drop to the 120amp range only because of the joint position in relationship to other materials.
If you post this on the tool forum then maybe BFO or Fred O. will respond as they have commented on this type of repair alot over the years. I believe both still have active shops going.
T_Bone
Billy NY
04-05-2006 14:02:01
 Re: Welding, upside down.... in reply to T_Bone, 04-05-2006 09:20:57
Not at all, there are some great minds here, I always sound defensive, for some reason. The items you have commented on makes good sense.
Good point, this repair is mirrored on both sides, and terminates before the bend on the c-shaped frame members. I think I'm going to plate the underside of the top flange, I'll practice up on the overhead welding, like you said, same as welding flat, except a little more dangerous with slag falling from above, have to be careful there. If for some reason I cannot achieve the correct results, I'll have someone do these 4 plates, I've got everything set up here to do it. The top flange plates would in theory be in compression, so as it was, there were no signs of over deflecting evident, so I think the upper flange plates may not be needed, but still good measure, at least they'll keep the integrity of the bend with as much continuity as was there before and then some, without over stiffening it. The bottom ones would seem to be in tension and are probably more intregal to maintaining the strength of the member. I have a hard time visualising rotational forces that wouold apply here and any other similar forces at work, but thinking once it is done, I'll monitor the section and see if any problems arise anyways.
I have not had much trouble with the electrode sticking lately, but did through trial and error figure out how the heat range affects the weld, I take scrap plate, make a 1" to 2" pass, from cold to hot on the amperage, until I like what I see. The 7018 seems to like the heat, does not do well under 100 amps on this machine. I was at 140 amps with 5/32" electrodes and it really did form a nice weld. I have been around that range with 1/8" electrodes as well. Polarity is set with electrode positive and I assume DC as I look at the switch. AC is in the middle and stick negative is on the bottom, which I assume to be DC but with the current flowing the opposite way.
One of the areas I need to learn more about is using this NT 251 trailblazer for thin materials, I would not attempt it at this point, a Votech course would be a great help here I'll bet. I do have a Lincoln 225, "buzzbox" as well, from the 80's, which I need to pull the cover and make sure no mouse nests are in there, looks new, but it sat for years, which I have not used yet, but have used others at the labs with 6013 1/8" electrodes with good success. Next I'll want to add the wirefeed to the NT 251, gettin way ahead of myself here though !
I'll post over in the tool talk board next time, it's a great skill to have and be able to use, especially in a crunch, had a stud break off for a shock on my truck once, had to be out of town for work the next day, sure was nice to be able to complete that repair on a sunday and be at work on time the next day.
PJBROWN
04-04-2006 05:17:24
I have been told that a DC welder works great for overhead work. I only have an AC welder not a AC/DC one,but I have been told DC is what to go with for upside down welding.
old
04-03-2006 20:43:09
Lower the amps, and you might want to try some 7014 rod. Alos if you smoke trow away your BIC lighter, ask why well weldinging and bic type lighters will get you killed. Another thing when welding and you want a real good wled always make 3 passes. One is your root wled one is thew make it look good and the last one is the topping. And if you want it strong thats the only way to go. Yep I'm a retired welder and learned form a retired welder. Hes 86 or 87 now
Billy NY
04-04-2006 16:07:02
 Re: Welding, upside down.... in reply to old, 04-03-2006 20:43:09
No, never smoked, but I hear you on that, I assume the hot slag burns through and the lighter becomes a grenade. That and the slag rolling into your ear. I've got some leather protection to use.
I learned about these passes while overseeing a 3500' long 20" to 10" dia. steel butt welded pipe job, in '94, the 2 fitters on this job were certified in the Exxon and Mobil refineries, one taught the other, we worked well together on the job and I learned a lot from them, when I had their work tested, all the butt joints were 100%, they really did a great job and I did enjoy observing with a shield on. It's a dirty, nasty, dangerous and toxic job, no doubt about it, especially in a 9 foot deep trench with water, they worked in some tough spots.
old
04-04-2006 17:33:50
 Re: Welding, upside down.... in reply to Billy NY, 04-04-2006 16:07:02
I learned about the lighter problem when I was in the navy. They had a guy doing some cutting and he was alone in a compartment doing it. When he didn't show back up when he should have they went looking for him. What they found was a hole in his chest where his lighter had been. Blew his heart away.
Billy NY
04-04-2006 18:05:38
 Re: Welding, upside down.... in reply to old, 04-04-2006 17:33:50
I read the urban legend article, seems Bic does not like any settled cases against them to become public knowledge.
That had to be an odd incident, and I'm sure it was thoroughly investigated. Hard to imagine, but they are minature vessels with fuel in them, I would not want to test the theory!
old
04-04-2006 18:28:43
 Re: Welding, upside down.... in reply to Billy NY, 04-04-2006 18:05:38
Well ever since I have either used a zippo or I don't carry a lighter on me. A zippo will burn but it will not blow up. I have seen to many bic and the cheap knock offs blow up for welding and even being thrown down hard on a raock etc.
bill in wny
04-04-2006 03:46:00
interesting article on Bic lighters
http://www.snopes.com/horrors/techno/lighters.htm
B. Abseck
04-03-2006 20:04:46
Billy, You want just a little less amperage or "heat" when welding overhead with 7018. If you have eighth inch rod it will lay in the seam better than the five sixteenths you use for your flat welds. If your weld runs out of the "V" you will need to turn your amperage down a little more. Tack weld two scrap pieces together and practice the overhead welding on the scrap until you get the amperage set right and the "hang" of how fast to move the electrode in the overhead pocket. That"s how we had our apprentices master this concept. You will really have fun with your welding once you get the hang of it. Have fun and work safe. Also helps to have leather sleeves so the bits of hot slag don"t burn you.
Davis In SC
04-03-2006 20:11:10
 Re: Welding, upside down.... in reply to B. Abseck, 04-03-2006 20:04:46
And wear some earplugs... A ball of hot slag will burn right through an eardrum...
