Tractor Talk Discussion Forum
Avery
Mike in Wi.
03-20-2006 15:57:43
Hi-looking at buying a 1948 Avery BF.The tractor runs out well.Has the original Wards tires on which are checked bad.What is this worth?THANKS
Gene Davis (Ga.)
03-20-2006 19:03:10
 Re: Avery in reply to Mike in Wi., 03-20-2006 15:57:43
If it is indeed a 1948 model, it cannot be a BF series. Minneapolis Moline did not purchase the B.F.Avery company until about 1951 so it is most likely a model "A" Avery. There were some Wards Twin Rows made that would have original Wards tires like you describe.
Leroy
03-20-2006 17:51:20
B. F. Avery would be the brand but what model? The A? the R? The V? Different models mean different prices, Single Front, Dual Front, Wide Front? Hydrolics?
Mike in Wi.
03-20-2006 19:18:18
 Re: Avery in reply to Leroy, 03-20-2006 17:51:20
I think it is a A .It has the single front wheel with hydralics.Thanks all
J. Schwiebert
03-21-2006 12:48:09
 Re: Avery in reply to Mike in Wi., 03-20-2006 19:18:18
The model A & R both use the Hercules IXB engine. The R has 4 speeds forward. The A has 3.
Tyler in SD
03-20-2006 16:42:34
I was thinking that $1000 should be tops, since it is a small tractor w/ bad tires.
