Tractor Talk Discussion Forum
Update cleaning fuel tank
Keith-OR
01-15-2006 10:46:59
thanks everyone for you input.
I decided I would make a hook and pull out everything I could that way, here is Picture of 90% of what was in this fuel tank.
Even a bird buried some where in straw and weeds (cheat grass and foxtail)
Now this pile is same size around as the tank.
Keith & Shawn
third party imageLink loading="auto" style="width:auto;height:auto">
Keith-OR
01-15-2006 12:06:50
 Re: Update cleaning fuel tank in reply to Keith-OR, 01-15-2006 10:46:59
Hurst, I am doing a test on another salvage tank I have to see how the sulphric acid will effect it. So far after 15 minutes has not effected the galvanize, just removing the paint. Sulphric acid is what professionals use to clean galanized drain pipes.
Will post my results later.
Keith & Shawn
evielboweviel
03-31-2006 18:47:46
 Re: Colorado Curt or Somebody.....HELP! in reply to Allan In NE, 03-31-2006 18:28:18
sounds good can have the tractor and plow ready in 15 minutes. the tires are still set out from plowing last fall.
Ron
Hurst
01-15-2006 10:58:29
Wow, you have a lot more patience than me. Are you going to flush it out with some acid still to make sure everything is out? Maybe some gas will work to flush it out and get the junk out of the tank. Good luck
Hurst
Bob
01-15-2006 11:14:18
 Re: Update cleaning fuel tank in reply to Hurst, 01-15-2006 10:58:29
Why would you want to use acid, and take the tin plating off of the terne metal tank???
