Tractor Talk Discussion Forum
OT: Motorcycle engine runs away..
Delta Bob
12-19-2005 15:53:56
I have a 1973 Kawasaki 2 stroke (F-9) that runs away when you start it. The only way you can get it to slow down is to put your hand over the carb.. The carburator slide is going all the way down to the stop.Need some help on this one.
craig loewer
12-19-2005 16:05:55
 Re: OT: Motorcycle engine runs away.. in reply to Delta Bob, 12-19-2005 15:53:56
I HAVE SEEN THIS BEFORE.IN MY CASE THE SLIDE WAS PUT IN 90 DEGREES OFF CAUSING THE IDLE SCREW TO HOLD THE SLIDE UP. ALSO CHECK THE FUEL JET,THE LONG POINTED STEM AT THE BOTTOM OF THE SLIDE IT SHOULD BE POINTED.IT COULD BE BROKE OR SEVERLY WORN IF THAT IS THE CASE JUST REPLACE.YOU CAN GET A CARB REBUILD KIT FOR AROUND 25.00 DOLLARS.
Mike from cny
12-19-2005 21:22:08
 Re: OT: Motorcycle engine runs away.. in reply to craig loewer, 12-19-2005 16:05:55
Check those crank seals, or other airleaks, they will cause it to rev up and run away.
Harley
12-20-2005 08:08:06
 Re: OT: Motorcycle engine runs away.. in reply to Mike from cny, 12-19-2005 21:22:08
I had a dog that ran away one time and I just shot it. Cheap, not much of a dog, and lasted a long time. Never ran away again. Harley
