Tractor Talk Discussion Forum
farmall throttle
DAVE DAHL
10-31-2005 18:03:15
i have a 49 M with a saw tooth style throttle lever, the tooth is worn down and it pops down (can't keep the rpm up ) is there a replacement avalible or a quick fix with keeping this lever mostly intact
Red Dave
11-01-2005 06:12:25
 Re: farmall throttle in reply to DAVE DAHL, 10-31-2005 18:03:15
I've fixed a couple of them by building up some weld, then putting the teeth back on with a three-cornered file. Not hard, works good, looks like original.
doogdoog
10-31-2005 19:17:07
Aloha, Other then what has been said, maybe you could get a triangular shaped file and refile the the worn tooth v's. Is it the tooth that are worn or the other ratcheting finger? Maybe you could increase the tension on the spring if it has one.
Mahalo,
doogdoog
RustyFarmall
10-31-2005 18:21:30
Aftermarket replacements are available from this site as well as several others. You can also build up the tooth on the lever by welding and then grinding it back into shape which works pretty good but is kind of a hassle to do.
