Tractor Talk Discussion Forum
Tractor roll over
dipnet
10-20-2005 17:30:06
Well I reported about getting my new tractor on Monday & turning it over on friday this is how it has worked out . First it is a Mahindra 4110.
I was pushing a tree that was laying on top of ditch bank . The tractor was in four wheel drive.
The tractor was on road bed . To the right side of the tractor the road sloped down about 20 degree slope . I had the bucket above ditch bank pushing small tree . The tractor was at a angel when I started down into the ditch so the left tire came in contact with ditch bank first when the left tire came in contact with bank it started climbing up bank . This cause the right tire to come off the ground .This caused the tractor to roll over to the right on its side. I know hin site is 20-20 If I had hit joystick and droped the bucket I could have recovered. I cut the engine off after it rolled on its side within 8 seconds. I call the dealer they said don't even try to crank tractor . When you get it back on its wheels . I call Mr. Mullens he brought his wrecker, he hooked one cable to rear axel and one to the front. He amazed me setting the tracor back on its wheels he did it as smooth and soft no bounce at all amazing job. I took the tractor back to the dealer they took the injectors out. when the tractor rolled on its side it did get oil on top of the pistons. If you try to crank a engine with oil on top of a piston it can bend a rod. I got he tractor back yesterday it is running fine . It does seem to be making a little more smoke out the exhaust. I would have had dealer put antifreez and water in rear tires but I think it would make the tractor to heavey to haul on my trailer.The tractor has a box blade and bucket.
the tractor weighs 3963 pounds by itself so I guess the bucket weighs about 800 pounds the box weights 300 pounds so that total is 5063 pounds . The trailer will carry 7000 pounds it has electric brakes. The issue is the bumper hitch on my truck it says it is rated for 5000 pounds and the tougth weight on ball is 500 pounds. I know my Z71 with toe haul will pull the trailer & V8 engine. I hope this report may prevent someone else from having to go through this. I want to thank the good Lord for protecting me from getting hurt!
George in Biloxi
10-21-2005 08:08:40
 Re: Tractor roll over in reply to dipnet, 10-20-2005 17:30:06
It is good that you and the tractor are o.k. The reaction of putting the bucket down has to come with practice, most people would not think that fast with out experience. The trailer sounds like a 7K trailer which is 7K gross weight and the trailer probably weighs another 15 or 1600 pounds. It sounds about right. You can adjust the tongue weight by positioning the tractor on the trailer (more forward or back) in relation to the axles. You need a healthy bit of tongue weight or the trailer will fish tail. This gets hairy real quick. If you can not get it adjusted right, the truck is not sized right for the combination.
good luck and be safe,
George
Jb
10-21-2005 06:28:25
We are all glad you are OK. Just woundering if you were wearing the seat belt and rode the tractor down.
Jerry/MT
10-20-2005 22:01:21
I'm glad you're OK. Thanks for writing the note. It might help somone from doing something similar.
Coldiron
10-20-2005 20:22:47
Dipnet, Thanks for letting us know the particulars on how the accident happened. Thinking of dropping the bucket and putting the clutch in may have stopped the movement but the blessing is that you were not injured and the tractor is in good shape. You are right about the hitch rating and the ball. I would get a heavier duty set up.
Mike Van
10-20-2005 17:58:54
Well, it sure happens fast when "things go wrong" Good news is, nobodys hurt, even the tractor wasn't totaled. You must have had an angel looking out for you.
jfp
10-20-2005 17:54:09
Glad you are back up and running.
danofarming
10-20-2005 19:00:33
 Re: Tractor roll over in reply to jfp, 10-20-2005 17:54:09
I would not own a tractor without filling the rear tires with fluid. I have it in my lawnmower.
