Tractor Talk Discussion Forum
318 O.T.( But I pull the tractors with it)
504
09-06-2005 19:16:24
Maybe someone here has already had and fixed this problem. 1995 Jeep Grand Cheerokee 5.2(318 for us old guys) when it is up to temp it misfires, jumps, bucks and is just about undriveable. Started out with a bad wire and o2 sensor. That took care of the codes but it runs worse than ever.TPS did not help,dist pick up did not help,next I`ll try a coil.
DigDugNC
09-07-2005 18:34:34
 Re: 318 O.T.( But I pull the tractors with it) in reply to 504, 09-06-2005 19:16:24
Question: If you are parked can you rev the engine and everything run fine? If so I think you are not getting enough fuel to the carb/inj. Did that on me once sitting still I could rev it up and she purred like a kitten, go driving down the road and at about 30-35mph did just like you described. Found out that the camshaft was worn were the manual fuel pump arm was at and when the motor was under a load (driving) it couldn't pump enough. I know your fuel pump isn't manual but sound like the same problem. If it don't run sitting still I agree with the others and look at replacing the dist./ and the coil.
david from mo
09-07-2005 12:48:02
I have seen dodge pickups with a worn dist drive bushing cause your problem. Remove dist cap (i know hard to get to) try to move rotor ,much movement you need bushing and new oil pump drive shaft ,this is a dealer job because the bushing must be sized AND DIST HAS TO BE SET TO FIRE INJECTORS.
RusselAZ
09-07-2005 07:35:00
If you changed the 02 sensor because there was a code for 02 sensor lean, or not switching etc, you need a fuel pump. THis vehicle has a returnless fuel system, the regulator is in the module in the tank and so is the fuel filter.
caseyc
09-07-2005 05:53:18
check your intake gaskets. along with the "main" ones there is a pan on the under side of the intake that will do what you describe when it's blown out. real comman for those 5.2/5.9s in all applications.
casey in SD
jfp
09-07-2005 05:17:16
What about Fuel filter. Water in the fuel does that condition also.
rotten robert
09-06-2005 19:40:31
Is that 95" a distributerless ignition system?
I ran into a 5.9 gas(360) that did about the same and eventually found it was a cracked flex plate throwing off the crank sensor that is mounted at the rear of the engine.
504
09-06-2005 20:57:57
 Re: 318 O.T.( But I pull the tractors with it) in reply to rotten robert, 09-06-2005 19:40:31
It has a distributer,you can hardley see it, but it is there.
504
09-07-2005 19:00:04
 Re: 318 O.T.( But I pull the tractors with it) in reply to 504, 09-06-2005 20:57:57
Well Guys I picked up a new coil(wrong one). I stopped by the dealer and had a little talk with the service manager, his best guess is the fuel pump. I`ll get it on a gauge toworrow.BTW a new pump is 220.00. The way this dealer has treated me on this Jeep the next one I buy I will realy try to buy from them.
504
09-09-2005 19:32:14
 Re: 318 O.T.( But I pull the tractors with it) in reply to 504, 09-07-2005 19:00:04
The shop found the problem! BAD GROUND at the computer.
