Tractor Talk Discussion Forum
A liquid to unstick valves?
Bilko
08-01-2005 17:43:06
Wondering if this was true or not. Some guys at work were talking about something you can buy some type of liquid to put in motor to unstick your sticky vavles. I have never heard of it and was wondering. Thanks Mike
Jerry/MT
08-02-2005 15:31:57
 Re: A liquid to unstick valves? in reply to Bilko, 08-01-2005 17:43:06
I had a neighbor with a Ford 9N that had chronic sticky valves. He put a pint of automatic transmission fluid in a full tank of gas and swore the problem cleared up. I know it's anecdotal evidence but he swears it works.
bilko
08-02-2005 11:38:16
Thanks everyone for the information. I am going to try and see if any of them will work for me. Thanks again MIke
Jay (ND)
08-01-2005 20:14:25
I've had good luck with SeaFoam.
Ludwig
08-02-2005 11:05:44
 Re: A liquid to unstick valves? in reply to Jay (ND), 08-01-2005 20:14:25
I've had EXCELLENT luck with Seafoam.
My Honda CB900f had a stuck needle in at least one of the carbs so it would pee gas out when I shut it off. I put Seafoam in and within a couple weeks it totally stopped and it runs great. Amazing stuff.
msb
08-01-2005 18:50:08
Old time remedy around here was to pour baake fluid down the carburetor until she smoked up the shop real good and then do it again.Cheap and worked like a charm.
buckva
08-01-2005 20:20:04
 Re: A liquid to unstick valves? in reply to msb, 08-01-2005 18:50:08
I also recommend the brake fluid
MarkB_MI
08-01-2005 18:06:41
Like Mark/txgrn, I've had good luck with Marvel Mystery Oil. I add it to the gas for my tractor and all my small engines. If I have an engine with a stuck valve, I'll dump it in the spark plug hole, down the carb or whatever it takes to lube the valves.
Before I put my generator away, I always dump a little extra MMO in the gas, then run the gas dry. Since I started doing this, valve sticking on my 1950 vintage Briggs & Stratton has completely disappeared.
txgrn
08-01-2005 17:49:50
You can buy Marvel Mystery Oil in the red container at wally world. Goes in gas and oil. Then get the engine to injest some. Easy in a car just remove the air cleaner and pour it in the air intake till the engine almost chokes (lotta white smoke out the tailpipe) then let her catch her breath and do it again half a dozen times.
Then turn her off and let her sit for a couple of hours and do it again.
If the plugs don't clean up on their own, take em out, clean em up and stick em back in. Be surprised how good it works.
On an updraft carb on a tractor you will need a squirt device to get it in the airstream. Some folks use diesel.
Mark
Van in AR
08-01-2005 21:22:00
 Re: A liquid to unstick valves? in reply to txgrn, 08-01-2005 17:49:50
I wouldn't put that in the intake of a late model car, you'll be buying O2 sensors in a little while.
Van
txgrn
08-02-2005 17:35:56
 Re: A liquid to unstick valves? in reply to Van in AR, 08-01-2005 21:22:00
Well we didn't. It was back in the early '60's. With the new clean fuels haven't had similar problems.
Mark
Mike M
08-02-2005 05:21:18
Or worse yet an engine ! Guy at work did a northstar those intake runners are real long,it didn't get sucked in,until he backed out over a little grade and made it all go into one cyl. Bent a rod.
txgrn
08-02-2005 17:37:21
 Re: A liquid to unstick valves? in reply to Mike M, 08-02-2005 05:21:18
These were carbureted V8 automobiles.
Mark
