Tractor Talk Discussion Forum
1948 farmal cub
paul Hamilton
07-10-2005 18:25:20
I just replaced the radiator. I put in anti-freeze and found that it leaks from the base. I cleaned the engine block thoroughly and installed the seal the company sent me. Do the bolts have to be tighened down in a specific way? Is there another seal I should know about?
Thanks Paul
Question ....
07-10-2005 18:33:33
 Re: 1948 farmal cub in reply to paul Hamilton, 07-10-2005 18:25:20
What exactly is leaking and where? What seal are you referring to?
paul Hamilton
07-10-2005 18:46:51
 Re: 1948 farmal cub in reply to Question ...., 07-10-2005 18:33:33
the seal bettween the base of the radiator and the engine block. Anti-freeze is leaking. Paul
Pete in Cal
07-10-2005 22:37:44
 Re: 1948 farmal cub in reply to paul Hamilton, 07-10-2005 18:46:51
If the gasket is cork it will leak. I coated mine with plumbers grease on all surfaces just before installation. Tighten bolts evenly, no particular sequence that I am aware of.
