Tractor Talk Discussion Forum
IMT / MF
SES
06-07-2005 04:34:18
Can any of you tell me if the manual for a MF35 with a Perkins Diesel will work to repair a IMT 539 with a Perkins diesel? Wor would it be a TO35 Diesel? I don't know the difference in the two. I have problems with the hydraulics on my 539 and can't seem to get it adjusted right. I have flushed the box several times thinking it might be contamination but it still has sporadic times when it will raise as high as it will go and will not release to go down unless you turn off the tractor. Next time I start it it returns all the way to the top. If it sits a day or two sometimes it will then work fine. Any ideas or help would be very appreicated. Thank you in advance.
the tractor vet
03-25-2006 11:36:17
 Re: Large 4 wheel farm wagons in reply to Jonfarmer, 03-25-2006 10:24:25
Well don't know on that but i do know that a 18 foot silage wagon filled is more then ya want at times behind a 806 weighen in at 12000 at times .
geok
06-07-2005 19:39:17
 Re: IMT / MF in reply to SES, 06-07-2005 04:34:18
The closes would be a MF 35. Sounds like your problem is the control valve. Are you using 90 weight GL1 oil in your transmission? your problem sound almost as if your control valve is not rocking from your main pump shaft and is hanging on it self.
