Tractor Talk Discussion Forum
786 TA won't stay up
Daryl Glaser
05-14-2005 06:21:22
I"ve got a 786INT. and the TA won"t stay engaged. Any ideas?
Redman
05-14-2005 21:12:49
 Re: 786 TA won't stay up in reply to Daryl Glaser, 05-14-2005 06:21:22
pull the plastic around the dash,sounds like the spring broke.
John in WV
05-14-2005 12:59:57
Your TA handle has a slot with a bolt in it for adjusment this can get loose, check through TA handle slot in dash.
the tractor vet
05-14-2005 06:36:43
What side low or the hi side???? Does the teltail lite come on ??? do you loose steering and brakes????? have you changed the hdy. filter lately ????? does the spool valve go all the way down to the snap ring on the valve and make contact with the base. It could be that your T/A shift cable is streched. Or on the down side ya need a new T/A - MCV pump - maybe a blowen gskt.-o/ring . Need more info.
