Tractor Talk Discussion Forum
8n Strarter Solenoid
Rino
04-23-2005 07:17:03
I"ve just started on an 8N project and have a problem identifying the correct starter soleniod. The tractor is 12 volt but the solenoid looks like 6 volt. It has the 3 connecters and the ones I have found on the internet with thre connecters are all 6 volt. The 12 volt one had four. Are all of the solenoids the same? Any idea where I can get the correct one?
Bob
04-23-2005 07:31:19
 Re: 8n Strarter Solenoid in reply to Rino, 04-23-2005 07:17:03
If you have a 12 Volt (converted) 8N, you can simply use the original 6 Volt solenoid. For the limited time the solenoid is activated during starting, the 6 Volt solenoid will normally work for years.
To keep the tranny-top safey switch in use (a MUST, for safety), you have to use the original type solenoid, as it's internal connections are different than most more modern sutomotive solenoids.
If you are electrically knowledgeable, there is a special type of modern solenoid you can use, by adding a jumper wire, however, keeping it simple and using the 6 Volt unit is probably the simplest and best solution.
Below is a link to another post on this subject.
