Tractor Talk Discussion Forum
Hot water and a stuck engine.
old
04-14-2005 08:20:34
Has any body ever tried running hot water in the cooling system of a stuck engine to help unlock it?? I've been thinking about setting up a rig to do that, I fugure if the engine got up close to as hot as it would be when running it might help unlock a stuck engine. Of course I'd still do the oil/tranny fluid /turpentine thing first.
Bernie in MA
04-14-2005 08:35:54
 Re: Hot water and a stuck engine. in reply to old, 04-14-2005 08:20:34
I did this 2 years ago on a 420JD. Plumbed an old 20# propane tank into the bottom of the block, filled everything to the top with water and heated the tank with a gas burner. The radiator was disconnecteted and the head was off. I drilled a piece of square tube to line up with the head bolts across the cylinder, put steel blocking under it on top of the piston and cranked down the bolts. Worked slick.
george md
04-14-2005 12:35:53
 Re: Hot water and a stuck engine. in reply to Bernie in MA, 04-14-2005 08:35:54
Bernie,
lost your email etc , hard drive crashed last summer .
How did you make out with the gear on sunday?
george
Bernie in MA
04-14-2005 17:31:47
 Re: Hot water and a stuck engine. in reply to george md, 04-14-2005 12:35:53
Hi George. Couldn't get it hot enough. I didn't realize that being in two pieces one side would cool off for the few seconds the other side was being heated. Gonna rent another brush torch Sat and try again. My nephew went thru tech school and knows all kinds of welding so I'm letting him do it. I never did any gas welding and very little brazing.
george md
04-14-2005 17:47:23
 Re: Hot water and a stuck engine. in reply to Bernie in MA, 04-14-2005 17:31:47
Bernie ,
wish I wasn't so broke and behind in work , I'd
bring some tools and come help.
Send me an email and I'll get the address from it
also put the phone # in it .
george
