Tractor Talk Discussion Forum
Anyone ever try Jet A-1 in their diesel?
Jeff C
04-03-2005 16:02:46
I recently came across a great deal on some jet fuel (Jet A-1) and was wondering if it"ll burn in a diesel engine without harming it(the engine that is!). Any thoughts?
Carm
04-06-2005 06:24:06
 Re: Anyone ever try Jet A-1 in their diesel? in reply to Jeff C, 04-03-2005 16:02:46
We use straight Jet A in our fuel truck(2000 International). I take the sump Jet fuel home all the time and burn some in the heating oil tank. For the Diesels, I have some old (unused) motor oil that is not (in my opinion) suitable to lubricate an engine, but OK to burn. I think I mix mine a little rich on the oil but have had no ill effects after about 8 years of doing so. I usually dump about half quart (unmeasured, give or take a bit) to a 5 gallon container. If you mix it with 50/50 Jet/diesel, which is what I do when my Jet fuel harvest at work gets slim (sopmetimes I have competition), that is ok too.
Jeff C
04-04-2005 06:54:08
Thanks for the input!.....Roughly how much 2 stroke oil should be added say to 5 gallons?
Sloroll
04-04-2005 06:56:02
 Re: Anyone ever try Jet A-1 in their diesel? in reply to Jeff C, 04-04-2005 06:54:08
I don't think you have to add any. But I would think 2-4 oz would be more than enough. or if you are concerned mix it 1/2 and 1/2 with diesel.
I Like Case
04-04-2005 06:04:48
Yep. I came across one of those deals on some "contaminated" Jet A myself. I got 110 gallons for hauling it away. I used it in my Bobcat, trencher, truck and 720 JD. Never noticed any ill affects or special benefits(other than it was free).
Tim B
04-04-2005 01:03:56
I used to be a crew chief / flight mechanic on a USAF HH-1H Huey Helicopter. We usually used JP4 fuel, but would routinely interchange JP5 & Jet A. We never had the occasion to try it, but according to the helicopter tech data we could also burn Kerosene or Diesel fuel. Based on that I would think if diesel is good enough for a helicopter, I would think Jet A is good enough for anything designed to run on deisel. Of course a little bit of added lube for the injectors would be a good idea.
Sloroll
04-03-2005 20:21:10
Many airports use only Jet! in their diesel equipmnet. Those little tugs running around are geberally Diesel. I usee Jet A in my 966 and many aircraft mechanics burn Jet A in their Diesel vehicles (buy diesel for just that reason.) It is Dryer. I usually add a ittle 2cle oil. Many dont.
buickanddeere
04-03-2005 20:02:57
Just remember to keep your WD-45 under 10,000 ft so you don't pass out from the lack of oxygen.
thejdman01
04-03-2005 18:33:16
better add some marvel oil or 2 cycle oil. also depending on the condition and climate your in maybe a tad harder to start.
thejdman01
04-03-2005 18:33:06
Bus Driver
04-03-2005 18:23:28
Several previous posts discussed this same question. A bit of 2-cycle oil added should take care of injector pump lube concerns.
champspa
04-03-2005 16:45:48
Jet a-1 is all the army uses it will burn in a cummins according to the manual.
Doyle Alley
04-03-2005 18:18:42
 Re: Anyone ever try Jet A-1 in their diesel? in reply to champspa, 04-03-2005 16:45:48
Jet A is a first cousin to kerosine. You'll find that it is "dryer" than diesel. I doubt it would provide proper lubricant for your injectors unless you added something "oily".
Sloroll
04-03-2005 20:22:20
 Re: Anyone ever try Jet A-1 in their diesel? in reply to Doyle Alley, 04-03-2005 18:18:42
It is grade A Kero. Generally has an anti-icer called Prist added.
