Tractor Talk Discussion Forum
8-N Starter
Randy Sowders
03-29-2005 07:21:37
I have an 8-N ford and i am having starter problems. Starter was replaced appox.1 year ago,soilenoid was replaced 1 week ago,all she will do is 'click' at the soilenoid,starter does nothing.Tractor will pull start fine. Would be gratefull for and and all suggestions, or my next message will read; FOR SALE 8-N tractor..... ...
Just joking...Thank you in advance for your help.
Steve (Magnolia, TX)
03-29-2005 07:31:23
 Re: 8-N Starter in reply to Randy Sowders, 03-29-2005 07:21:37
Assuming that you've checked your battery (and you're sure that it's good), I'd check all of your battery connections. Make sure that they're clean and tight (and don't forget the ground strap connection to the tractor).
HTH
Steve
FarrviewSouth
03-29-2005 07:30:50
I agree your tractor is junk. Therefore, please tell me where you are located and I will remove it from your yard as a favor to you :>
Or, 6 volt systems hate dirty cables, grounds etc.
I would first check to be sure battery is fully charged, disconnect and clean both cables at each end and try again. If that does not work, then remove starter and try it on the bench under no load and post result.
