Tractor Talk Discussion Forum
sprocket bolts
joe moore
02-05-2005 15:57:41
I have a HD3 Tractor with backhoe attached, using the machine all bolts fell of the sprocket..where can I locate new and proper steel bolts I need 8..
I do not have a tractor supply in my area or nearby in the northeast corner of Connecticut..Is it possible to use lugs as per trucks????
All information where items can be purchased will be appreciated...
hector gemme
02-08-2005 08:41:56
 Re: sprocket bolts in reply to joe moore, 02-05-2005 15:57:41
HEI I HAVE FINAL DRIVE ANDSTERING CLUCH BUT NO BOLTS YOU CLEANTHE BOLTS AND PUT LOCKTITE ON
Roy Suomi
02-05-2005 21:17:54
Joe , Are the bolt holes loose with a new grade 8 bolt?? I have used Locktite on the threads on some questionable threads. Torque the bolts to specs.
jmoore
02-05-2005 17:40:05
I don't know if the bolts you have are special, but would seem that a good hardware should have them or at least order you some.By the way that/s a good name you have there! Regards Joe Moore From Michigan
