Tractor Talk Discussion Forum
Help!! frozen choke in my wheelhorse tractor
Patricia
01-22-2005 12:09:54
Help! I live in upstate NY and we are getting hammered with snow...the choke in my Wheelhorse tractor w/snowplow attachment is frozen. Normally, I get out there with a heatgun and thaw it out, but today that is just not working.
Any suggestions? Thanks very much.
sammy the RED
01-22-2005 13:51:50
 Re: Help!! frozen choke in my wheelhorse tractor in reply to Patricia, 01-22-2005 12:09:54
After you get it lose, give it a healthy dose of JB-80.
old
01-22-2005 13:17:55
Pout some alcohol on it, it will dry out the water/ice and will not hurt the engine if you get a little in to the carb.
leland
01-22-2005 12:53:50
Get a spray can of winshield de icer cheap at w-mart spray cable good and let sit for a while until loose, then use good with a teflon lube this will help is your cable just a plain silver one or does it have a plastic cover on it?
Patricia
01-23-2005 09:51:12
 Re: Help!! frozen choke in my wheelhorse tractor in reply to leland, 01-22-2005 12:53:50
Many thanks to those of you who responded with suggestions. Leland, the cable has a plastic cover. I decided that the heat gun wasn"t doing the job so I brought out the hairdryer. That worked better. I concentrated on the lowest part of the cable and finally got it to move.
Thanks again for your suggestions.
P.
leland
01-24-2005 05:56:11
 Re: Help!! frozen choke in my wheelhorse tractor in reply to Patricia, 01-23-2005 09:51:12
Just spray both ends good with a teflon based lube this will help keep it from sticking , then hit it every time after pushing snow . I assume that after watching TV you have quite a bit of snow to move.
Patricia
01-27-2005 05:04:03
 Re: Help!! frozen choke in my wheelhorse tractor in reply to leland, 01-24-2005 05:56:11
Hi Leland,
Yes, here in the Hudson Valley, NY, we had about 14 inches of snow over Saturday/Sunday and then another 4 inches yesterday. On Monday, I bought a new (stronger) heat gun at Home Depot and when I went out to plow this morning, it only took a few minutes. I will look for the de-icer that you suggested and will follow your direction. Thanks again.P.
leland
01-27-2005 05:44:12
 Re: Help!! frozen choke in my wheelhorse tractor in reply to Patricia, 01-27-2005 05:04:03
I feel bad now we have sunshine 35* and no snow.
Brad roupp
02-19-2005 18:02:01
 Re: Help!! frozen choke in my wheelhorse tractor in reply to leland, 01-27-2005 05:44:12
there must be water in the fuel or the snow must be getting in or around the choke .try cutting a plastic soda bottle and placing it over the choke area.
