Tractor Talk Discussion Forum
Loading rear tractor tires using a pressure tank
TrapperJohn
09-16-2004 19:24:45
Does anyone use a water pressure tank to load tractor tires? What kind of attachments did you purchase or make to facilitate hooking the hose from the tank to the valve stem? I'd appreciate your ideas!
Thank you!
TrapperJohn
09-17-2004 14:28:52
 Thank you! in reply to TrapperJohn, 09-16-2004 19:24:45
Thank you! Both were good ideas! Gemplers has the adapter, so I'll order it there.
Thanks Again!
poorfolk
09-17-2004 03:36:16
 Re: Loading rear tractor tires using a pressure ta in reply to TrapperJohn, 09-16-2004 19:24:45
i took the little hose from a can of fix-a flat,found a gas line shut off that switched to a size bigger added a hose and viola.
TheRealRon
09-17-2004 02:56:29
See www.gemplers.com.
