Tractor Talk Discussion Forum
generator cutout
wilqhorse
09-10-2004 20:26:48
My Cockshutt 30 with the original autolite generator has a cutout and the charge rate is controlled by a resister in the light switch. I need the proper switch.The generator charges but I have no control, I tried a heater switch with a resister for a 2 speed fan but it doesn't work can anyone help???
Alberta Mike
09-11-2004 06:04:57
 Re: generator cutout in reply to wilqhorse, 09-10-2004 20:26:48
Hello fellow Cockshutt 30 owner .... I've seen those switches advertised in the Antique Power Magazine, I think the name of the Company is "Agri-Services" or something like that but they are pretty pricey. Maybe try a Google search for that. You need to feed the generator's field circuit through a 3 ohm ceramic resistor and then to ground. That will give you the same control that those old light switches provided. The generator itself can be adjusted to control it's output at the generator itself by adjusting the relative position of the 3rd brush inside the generator housing on the end plate. Email me if you like, I have removed the hide feature from my name link.
