Tractor Talk Discussion Forum
Wheel Plroblems
travis t
08-07-2004 17:40:03
I have a 38 A john deer that the rear wheels are set all the way out, and I want to move them in but we cant seem to get them to move. If anyone has any tips it would be great.Thanks!!!
Leland
08-07-2004 20:32:03
 Re: Wheel Plroblems in reply to travis t, 08-07-2004 17:40:03
If yours has one I have found it is eaiser to slide wheels with the keyway on bottom. This keeps the wedge from catching.
RJ-AZ
08-07-2004 18:47:06
Travis this is kind of tricky but it works. Loosen the clamps and use plenty of penetrant on the axles. Drive it around very carefully and maybe HORSE it with the turning brakes untill the wheel hub loosens on the axle.
Another method is to thread a chain through the wheel and back to the tractor attatching it to the drawbar and the other end forward of the seat. Jack the tractor up and rotate the wheel and as the chain winds up it will pull the wheel in.
Be very careful and use some common sense and it can be done safely.
