Tractor Talk Discussion Forum
Hercules external water pump
Fred
05-12-2004 07:03:22
What are the tricks to replacing the packing in a water pump on a 1932 Hercules motor? It is on a Massey-Harris GP. This is my first experience with a mag. set-up and an external water pump(so I know 0 about it). Any step by step help would be great. Thanks
Duner Wi
05-13-2004 06:17:05
 Re: Hercules external water pump in reply to Fred, 05-12-2004 07:03:22
Generally with a system such as yours I would loosen the packing nut and slide back on the shaft.
See what is in there. Could be all you need to do is add or replace the packing which I obtained at plumbing supply house. Pretty much just string and graphite with maybe some sort of lubricant added. Don't over tighen the packing nut, take it up bit by bit. I never worked on a M-H GP, this is just general info.
