Tractor Talk Discussion Forum
Massey 30 or 101 JR
Kevin WI
04-22-2004 18:18:26
I bought a Massey but I am not sure what it is. The date on trans housing is 5-16-46 162 on engine plate. Tractor plate is gone 4speed trans Thanks
Dave_Id
04-22-2004 21:30:19
 Re: Massey 30 or 101 JR in reply to Kevin WI, 04-22-2004 18:18:26
It's a good chance it is a 101 Jr, from 43 to 46, the Jr was fitted with the 162 Continental, and the Model 30 came out in 1947, but do as Mike suggests, and get the ser. number to find out exactly what it is...
Alberta Mike
04-23-2004 03:48:41
 Re: Re: Massey 30 or 101 JR in reply to Dave_Id, 04-22-2004 21:30:19
Didn't know that about the engines in the Juniors. Learn something every day. I wonder how he knows it is a '46?
Dave_Id
04-23-2004 10:56:09
 Re: Re: Re: Massey 30 or 101 JR in reply to Alberta Mike, 04-23-2004 03:48:41
I read that in Keith Oltrogges "Massey Tractor Data Book", but there are lot's of mistakes in the book.
Alberta Mike
04-22-2004 20:13:33
I'm guessing a model 30 if it has the 162 cubic inch version of the Continental flathead. Also, the Juniors had hinged sidepanels while the model 30 had the hood and sidecovers as one unit. The serial number is hand stamped into the upper machined surface of the transmission/differential casting. More specifically, between the rear steel plate covering the gears and the cast iron shifting platform (has the 1,2,3, etc. on it) that is in front of it. Go between these two covers to the left side (near the clutch pedal location when out) and the number is there, big numbers but maybe not stamped in too deeply so you'll have to scrape and wire brush to find it but it will be there. Post the number here and someone will ID it for sure as to year and model.
Kevin (WI)
04-23-2004 04:52:15
 Re: Re: Massey 30 or 101 JR in reply to Alberta Mike, 04-22-2004 20:13:33
Thanks Mike I found the serial number Just where you said it was Stamped JRE 504664. It also has the hinged side covers. Thanks again 101JR?
Alberta Mike
04-23-2004 10:11:22
 Re: Re: Re: Massey 30 or 101 JR in reply to Kevin (WI), 04-23-2004 04:52:15
Yup, it's a '46 ... about half way through that model year and as Dave says, that was the last year for the 101 Junior line (replaced by the model 30). That last year started at 503779 and ended with 505513. Yours would be a rowcrop, I don't think I've seen the J before (maybe means Junior) nor the E, I'm not sure what that would be. The R would be the rowcrop (narrow front) I'd guess.
