Tractor Talk Discussion Forum
Kohler KT17
Bill C.
04-12-2004 12:18:53
Can anyone tell me if there is a difference in camshafts between the Series I and Series II KT17 Kohler engines? I have a series II engine needing rebuild (threw a rod, broke the cam in half), and have a used Series I cam. I think the part numbers might be different but I thought the only differences in the engines had to do with the oiling system (or lack of).
Ron
04-13-2004 06:09:01
 Re: Kohler KT17 in reply to Bill C., 04-12-2004 12:18:53
Not sure if there is any difference in the cams...the engines sure lok about the same except fot the oiling systm in the series II....
I only use straight 40W Castrol in ours..both seriesI and a replacement seriesII..and in all the other air-cooled engines here in the summer, and have not had a problem since I changed to the 40 wt... I was told that the Series I should always be filled 1/4" Above the full mark....after one threw a rod...!! I would put dual exhausts on it while it is out..gets rid of a lot of heat, and back pressure--sounds good too....
