Tractor Talk Discussion Forum
differences between 300U and 350U
Brian
03-25-2004 04:11:02
When I bought a tractor I was told it was a 350U, when I got it home, I looked farther I noticed a c-169 on the motor block, I looked in the shop manual and realized that it was'nt a 350 but a 300. Could someone tell if there is some thing or some way that I could tell the two apart (there is no emblem) appreciate any help, Thanks
TDK
03-25-2004 21:43:37
 Re: differences between 300U and 350U in reply to Brian, 03-25-2004 04:11:02
Brian, the clutch pedal does go under the footrest on 350U, but this pedal setup was started on the 300U with tractor ser. # 31927.The rear work light was changed from the right fender to the left on 8-'56. There was a fuel tank heat shield added on 12-'56. The 300 had a key start switch,350 had key switch with push-button start.Does tractor have fast-hitch with traction control? These were only offered on 350's , but could've been added to 300. Any or all of the above could have been changed,modified,etc. over the years. Production for 300U ended on 9-'56 & production for 350U started on 11-'56. Info gathered from "Original Farmall Hundred Series by Fay & Kraushaar".Hopefully this will help you nail down which one you have. We have 1-350U & 4 1/2 300U's.Great tractors! If I can be of any more help send me an e-mail.
Ken in Pa
03-25-2004 20:58:21
I have had three 300U's and one 350U and have a fair amount factory books on them, and it seems the only diference between the two motors is that the 350U has a 1/6th bigger bore.
big fred
03-25-2004 13:34:01
Look at your steering wheel. If it has a nut in the middle, it's a 300U, if it has a plastic emblem (or place for one) it's a 350U.
BOB-WYO
03-25-2004 09:49:06
third party image
Brain don't know if this will help, but here is a pic of a 1958 350U
Bob
Irv
03-25-2004 17:00:54
 Re: Re: differences between 300U and 350U in reply to BOB-WYO, 03-25-2004 09:49:06
Nice tractor! Where did you get that rollbar/awning? I want one for my 300U! Thanks, Irv
Brian
03-25-2004 13:16:25
Does the arm on the cluth go underneath the footrest on the 350U and straight down on the 300U if so then I have the 350U but have a c-169 motor in it. I just needed to know so I could buy the right manuals.
old
03-25-2004 08:10:02
From what I have found you have already found the way, I had the same problem I thought I had a 350 or 400 and found out it was a 450 because of the engine number of C-281
Brian
03-25-2004 13:20:37
 Re: Re: differences between 300U and 350U in reply to old, 03-25-2004 08:10:02
Old, I don't mind getting a upgrade in the what I thought I was getting. but being told I getting a 350U and getting a 300U motor, but I don't know if there is much difference in a c-169 to a c-175 maybe a few horses
old
03-25-2004 15:34:23
 Re: Re: Re: differences between 300U and 350U in reply to Brian, 03-25-2004 13:20:37
Ya theres about 5 hp differance in the two other then that they are almost the same
