Tractor Talk Discussion Forum
801 Ford SOS
Garry Cottrell
02-07-2004 18:11:00
I have a farm tractor 1962 Ford select-o-speed and need a transmission.I found one from a 1966 Ford 3000 select-o-speed.Will this trans. fit my 1962 Ford 801? Thanks so much GARRY
Duner Wi
02-08-2004 19:24:47
 Re: 801 Ford SOS in reply to Garry Cottrell, 02-07-2004 18:11:00
Check the archives on the Ford board. Type in "SOS" Lots of info.
Larry
02-08-2004 05:34:07
I agree with coonhunter the 801 is a good tractor. But do yourself a favor, select-o-speed parts are hard to come by, put in a manual transmission and the tractor will last a life-time. It will cost a little more but if your tractor is in good condition it's well worth the cost.
Sam MI
02-08-2004 05:17:28
The SOS from the 3 cylinder tractors will not fit the 4 cylinder version tractors.
coonhunter
02-08-2004 04:54:28
For a little more money you can convert it to a 5 spd. and have a much better unit when you're done. And alot more resale value to-boot!!!
Harrison
02-07-2004 18:29:01
Should.What kind of warranty? Band adjustments are critical on a S-O-S.Use the manual.Simple tranny though.
Garry
02-07-2004 20:11:20
 Re: Re: 801 Ford SOS in reply to Harrison, 02-07-2004 18:29:01
No warranty that's why I need to know for sure.Cost quoted $350.
JEFF
02-08-2004 18:10:55
 Re: Re: Re: 801 Ford SOS in reply to Garry , 02-07-2004 20:11:20
If you can find a 5 speed the s-o-s is a p-o-s the 5 speed will increase the valve of the tractor and its a much better trans
