Tractor Talk Discussion Forum
Dumb question about Case 2390
zoidberg
01-15-2004 06:06:26
Hello, Would it be possible to move the exhaust stack on the 2390 or 2590 to a hole cut into the center of the hood. I would like to use this tractor (if I buy it) for cultivating but the muffler and stack block the entire left window. Looking for knowledge, and this seemed the place to go. thanks
i r baboon
01-15-2004 13:37:13
 Re: Dumb question about Case 2390 in reply to zoidberg, 01-15-2004 06:06:26
u may move her under the machine & to rear of r axle, a la ferguson, ford. no cutting, cheap muffler from j c whitney. be blessed
Joe Dirt
01-15-2004 10:58:14
I suppose it could be done with enough work. BUT...
Remember how the hood opens. The hole in the hood would have to be really big!
Greywolf
01-15-2004 06:56:33
If you would move it to the center, you would have to rework the air intake, that is in the center under the hood from factory. Plus you would have to attach the muffler to the hood solid and use a "bell coupler" to match the two sections of exhaust when you lift the hood.
If you use it for cultivating, you are more than likely looking down at the row for guidance, the muffler is above that line of sight. I don't use the 2590 for cultivating, can't get the rear wheels pulled in tight enough to use in 30" rows. And I use a mirror for guidance and that mounts on the right side of the frame.
Alvin n Ms.
01-15-2004 06:21:14
A muffler shop can bend and shape exhaust pipe to move it any where there is room, to do so. You may have to add some kind of support or brace. alvinnms
