Tractor Talk Discussion Forum
Block heater? 5 degs out and started nice!
Willy-N
01-03-2004 15:33:29
I have a block heater in my Massey 135 Gas but it is 5 degs out and it fired right up no problem with out pluging it in. It is supposed to drop down to -15 in the next few days I will try it then and see how it starts. Might have to plug it in not sure yet. Mark H.
Jimmy King
01-04-2004 09:29:13
 Re: Block heater? 5 degs out and started nice! in reply to Willy-N, 01-03-2004 15:33:29
Willy if you have a block heater in your 135 use it any time it is below 30Deg. most engine wear comes in the first few seconds of starting a cold engine, and using a block heater will reduce this wear.
Dale
01-04-2004 08:12:02
Better to plug it in when it gets that cold whether it will start or not, easier on the engine. Our loader tractor has a block heater and a transmission heater, when it gets down to -55 at night it's sure nice to be able to start using the loader first thing in the morning instead of having to wait an hour for the hydraulics to thaw out.
Willy-N
01-04-2004 09:15:12
 Re: Re: Block heater? 5 degs out and started nice! in reply to Dale, 01-04-2004 08:12:02
That is a peoblem my Power Steering needs to warm up to not be a problem. I wish I had a heater on the resivor to warm it up! Mark H.
RAB
01-03-2004 22:52:07
If I were to have a heater and able to warm tne engine, I would. More wear takes place when the engine is cold and any increase in temp must be worthwhile - and economic if electricity is cheap enough, as liqid fuel is expensive for warming up an engine.
Hope to fit a heater system to my car today, so it can demist/defrost before I leave for work as well as having a warm engine and interior.
Regards,RAB
CH
01-03-2004 20:53:39
Send thoughs temps our way and hold the snow. I want the lake to freeze so if I get time I can do some fishing. I wouldn't think a 135 gasser would need a heater. My 245 diesel doesn't need one till it gets under 10, then it just starts faster. Better for the engine to have warm oil.
Keep warm.
Snowey
01-03-2004 18:23:00
Willy Did you put a new block heater in your 135 ? Next was the block heater on right side of motor ? I have a 2135 and I am thinking of puting a block heater on it . Thank You Snowey
Willy-N
01-03-2004 18:45:52
 Re: Re: Block heater? 5 degs out and started nice! in reply to Snowey, 01-03-2004 18:23:00
I have one in the block I belive in the head now. I have not used it yet or last winter. Not sure how cold it needs to be befor it is needed? Would help warm the engine befor starting but it starts now no different when 40 degs or 5 deg out? Mark H.
rhudson
01-03-2004 18:17:32
I don't know how you fellows deal with that kinda weather, mid 70's in virginia today. if we ever had - temps, our blood would stop flowing. the problem is it does not feel like Christmas around here until sometime in Feb.
Willy-N
01-03-2004 18:48:59
 Re: Re: Block heater? 5 degs out and started nice! in reply to rhudson, 01-03-2004 18:17:32
Right now I could go for 70 degs outside! It is 3 degs and 50+ mph winds allmost -30 below wind chill and supposed to drop to -15 tonight and that's not wind chill either?! Mark H.
stumpy
01-03-2004 18:57:14
 Re: Re: Re: Block heater? 5 degs out and started n in reply to Willy-N, 01-03-2004 18:48:59
Willy.... Don't even send that stuff my way (NH) been raining and about low 40's. Makes for easy winter. :)
stumpy
Willy-N
01-03-2004 19:28:11
 Re: Re: Re: Re: Block heater? 5 degs out and start in reply to stumpy, 01-03-2004 18:57:14
I will trade you some cold for rain anyday! We need a whole bunch of that to catch up from a 5 year drought. Mark H.
