Tractor Talk Discussion Forum
Hyd. pressure at front buckets?
Loren
08-27-2003 17:56:08
What is the common pressure available on tractors with onboard hyds? 1000 lb., 2000 lb? ???
paul
08-27-2003 18:23:28
 Re: Hyd. pressure at front buckets? in reply to Loren, 08-27-2003 17:56:08
Yes.
That is, the older ones are just over 1000, maybe 1500. The new ones go 2000 - 21000 - they often have their own relief valve just for the loader & can set the same loader to different pressures depending on size of thractor.
Some go more, and a worn out pump will go a lot less.
What tractor do you have, regular pump or a front-mount pump?
--->Paul
Loren
08-27-2003 19:17:18
 Re: Re: Hyd. pressure at front buckets? in reply to paul, 08-27-2003 18:23:28
Mines a Ollie 77 with a front pump but I'm figuring a specialized use unit for sale that will replace the bucket on tractors in general and need to know the available power. Thanks guys. Hey, are the little compact tractors the same situation with pressure?
paul
08-28-2003 10:49:15
 Re: Re: Re: Hyd. pressure at front buckets? in reply to Loren, 08-27-2003 19:17:18
Never really know what a front pump puts out, need a pressure gauge to check it out.
New compacts run around 2000, older ones were sometimes 1500-1800.
--->Paul
Thank you folks.
08-28-2003 18:25:24
 Re: Re: Re: Re: Hyd. pressure at front buckets? in reply to paul, 08-28-2003 10:49:15
ntxt
nhboyd
08-27-2003 18:00:00
1800 to 2000 is quite common. some tractors run as high as 2800.
