Tractor Talk Discussion Forum
t-20 electrics
bobs
08-04-2003 12:50:27
have a t-20 crawler with a gear drive generator and battery and a dist,but no electric starter.question is was there ever a electric starter and if so where would the opening be located? any and all ideas appreciated. tia
JerePa
08-04-2003 18:13:22
 Re: t-20 electrics in reply to bobs, 08-04-2003 12:50:27
It is very doutful it is a starter/gen. T20s never came through with a starter. Could be someone retrofitted a update kit to it. I would have to look up in my service letters to see if they had one. T20s usuall always used magnetos.
Tim
08-04-2003 20:05:11
 Re: Re: t-20 electrics in reply to JerePa, 08-04-2003 18:13:22
Never heard of a retrofit starter. Last I knew there weren't even teeth on the flywheel. All T-20's were hand crank.
JerePa
08-04-2003 20:20:05
 Re: Re: Re: t-20 electrics in reply to Tim, 08-04-2003 20:05:11
Right you are. I was refering to a retrofit distributor to replace the F4 mag. I doubt the starter could drive back through the dist./gear train.
Howard Yoshida
08-04-2003 15:46:48
Aloha, Since the generator is gear driven, could this be a motor-generator? In other words, starter and generator built into one.
Mahalo,
Howard
bob s
08-04-2003 16:23:33
 Re: Re: t-20 electrics in reply to Howard Yoshida, 08-04-2003 15:46:48
will check it out,may take awhile since tractor is up the road a piece,two hours by pickup.thanks for idea
