Tractor Talk Discussion Forum
Lube
Doug
07-28-2003 03:30:04
Can anyone take a moment and tell me where the lube fill location is for the rear end, clutch and pto of a '43 H. Also what lube is recommended and quantities? Thanks in advance
Leroy
07-28-2003 05:35:31
 Re: Lube in reply to Doug, 07-28-2003 03:30:04
The answer is assuming that you have a Farmall H, But you do not say if it is indead a Farmall or if it is in fact a John Deere and that would be a lot different, TOO many models of same identification in different makes, We need that make as well to help.
rustyfarmall
07-28-2003 05:21:44
The clutch is a dry clutch, so no oil in there, but there are several places that need lubed with a grease gun, the location for filling the rear end is on top of the deck, right close to the shift lever, it has a square hole in it for putting a wrench into for removal, there is a 1/2 inch pipe plug down on the side of the transmission, use this for checking the level.
85w-90 gear oil is what goes in there.
Do yourself and the tractor a big favor, buy a manual.
