Here is the receipe from my Oliver manual. If you live in a location where there is no freezing, just use water. Where freezing is a problem, use a mixture of calcium chloride and water. You need to determine how much solution first. I'll list some tire sizes and amounts. You judge from there 10-28 44 lbs of Calcium Chloride 22 gallons of water to minus 20 F. 228 lbs of total weight 72 lbs to 20.5 gallons of water to minus 40 F 244 lbs of total weight 11-28 62 lbs of Calcium Chloride 31 gallons of water to minus 20 F 322 lbs of total weight 102lbs to 29.25 gallons of water to minus 40 F 345 lbs of total weight 12-26 68 lbs of Calcium Chloride 34 gallons of water to minus 20 F 350 lbs of total weight 111lbs to 21.75 gallons of water to minus 40 F 376 lbs of total weightFill each tire about 75% full with air. Fill your container with the correct amount of water and add the required quantity of calcium chloride. WARNING When calcium chloride and water are mixed, a violent chemical reaction occurs which causes high temperatures. Add the calcium chloride to the water and stir-- DO NOT ADD THE WATER TO THE CALCIUM CHLORIDE. Be sure to let the liquid cool before attempting to fill the tires. After the calcium chloride and water solution has cooled, proceed to fill teh tires with the liquid. To do this, obtain an adapter and a length of ordinary garden hose. The adapter should have an air escape valve built into it to allow the air in the tire to escape as the liquid runs in. To install the calcium chloride and water solution. raise and block the tire off the ground, and rotate the wheel until the valve stem is in the uppermost position. Remove the valve core and connect the adapter. With the use of a tank above the level of the valve or a pump force the liquid into the tire until it begins to overflow through the relief valve of the adapter. At this point the tire is approximately 75 per cent full. Install the valve core and inlate the tire to the required air pressure. Check the tires with a gauge designed to be used on tires containing an anti-freeze soluton. Wash the gauge throughly after the tires are checked to remove all traces of calcium chloride. A conventional tire pressure gauge will be severly damaged if it is allowed to come in contact with calcium chloride. Having typed all that in. Wouldn't you really rather use wheel weights or have someone else do it for you? Hope this helps. Remember, I got this information from my manual. Others may have better advice for you. good luck and be careful, that stuff is corrosive. It will eat your rims like a teenager at a smorgasboard.
