With the talk of pickups pulling trailers exceeding their GVW ratings on both how about this.I'll bet that there isnt a single 2 ton farm truck in the country that doesnt far exceed their GVW rating.I went out and checked mine this morning and was surprised.Its not something that you think about.My 1968 IH 1800 2 ton farm truck has a GVW rating of 22,500 lbs.It has a 16 ft steel bed with hoist and weighs 9800 lbs empty.It has (6) 9.00x20 tires rated at 4610 lbs each. It has no extra top sides and always weighs nearly 30,000 lbs loaded at the grain elevator which is legal on the axles.There are other 2 ton grain trucks with extra top sides hauling far more grain than mine. If I were to load it by the GVW rating I could only haul a little over 200 bushels which would make it worthless. My 1969 IH 1600 Loadstar 2 ton farm truck has a GVW rating of only 18,200 lbs and weighs 9200 lbs empty.It has a 16 ft steel bed with wood floor and hoist.The steering tires are 9.00x20 rated at 4610 lbs.The rears are 8.25x20's rated at 4050 lbs.I'd have to change the rearend to put 9.00x20's on it. I usually weigh 30,000 lbs loaded.If I loaded to the GVW rating I could only haul 150 bushels which would make it absolutely worthless. Would you say that these trucks are safe or very unsafe?Lots will say that I should get a bigger truck.OK,if I were to buy a 10 wheeler that could weigh 48,000 lbs I'm guessing that with a legal load that I would far exceed my GVW rating on it.It would probably only be in the upper 20's-low 30's on GVW. OK,I went out and checked the GVW on my old 1966 CO 4000 IH road tractor with a 318 Detroit and a 10 speed.Its GVW is 35,000 lbs.If I stretched it and made it in to a 10 wheeler that can weigh 48,000 I would exceed the GVW by 13,000 lbs.Thats way more than my 2 ton trucks.Would that be safe or unsafe? So,if we wanted to get technical a semi with a grain trailer would be the only way I could safely haul grain to the elevator. Just something to think about.How much do some of you haul on 2 ton trucks?
