I read here that the new rule says we need to use four tie downs. That only applys to anything over 10,000 lbs. here is the rule for under 10,000 lbs. Hope this helps BUDD § 393.128 What are the rules for securing automobiles, light trucks and vans?(a) Applicability. The rules in this section apply to the transportation of automobiles, light trucks, and vans which individually weigh 4,536 kg. (10,000 lb) or less. Vehicles which individually are heavier than 4,536 kg (10,000 lb) must be secured in accordance with the provisions of § 393.130 of this part. (b) Securement of automobiles, light trucks, and vans. (b)(1) Automobiles, light trucks, and vans must be restrained at both the front and rear to prevent lateral, forward, rearward, and vertical movement using a minimum of two tiedowns. (b)(2) Tiedowns that are designed to be affixed to the structure of the automobile, light truck, or van must use the mounting points on those vehicles that have been specifically designed for that purpose. (b)(3) Tiedowns that are designed to fit over or around the wheels of an automobile, light truck, or van must provide restraint in the lateral, longitudinal and vertical directions. (b)(4) Edge protectors are not required for synthetic webbing at points where the webbing comes in contact with the tires. [67 FR 61234, Sep. 27, 2002]
