Tool Talk Discussion Forum
Re: Seized tractor top links
Steve@Advance
09-10-2015 17:49:28
"To restore it I placed brazing wire in the slot and arc welded over it . The heat from the arc melted the wire and formed around the threads , the end turned freely after this."
Very interesting! Can you elaborate? When you slit it, how deep did you go? And when welding it up, did you weld it with the threaded rod in?
Thanks!
