why your boiler was getting to Hot is maybe the Temp. Control on the Front of the Boiler -- on most, or on the back, is not working, that will turn on the Draft Fan and turn it off. Putting Water on the Fire may not have hurt the Boiler, because those Boilers don't have a Metal Bottom, and if you had the boiler full of water, then it should be O.K. But it could be you didn't do the Draft Fan any good by the Water, take it off and dry it out, and then put Power to it for just a second, if it starts, then it's O.K. but if it don't then take it to a Motor repair Shop for a replacement or repair. Replace your Temp. Control and when you put your Draft Fan back on, and your Temp. Control, just turn the control up and down with a screwdriver, and it should trun the Draft fan on and off, Set the Temp Control to your desired Water Temp. I have mine at 170* F Make sure the Boiler is full of Water at all times, you can remove the Rubber Water Ballest on top of the Boiler if there's one there, they just ware out and give problems, the Vent on top of the boiler will remove any excess water, and as long as the Boiler is close to Full of water, it won't create any problems. the Heatmor Boilers have a tendency for the Welds to leak, they must not have good Welders up in War Road MN. from my perspective. more over, the Boiler has to many Welds for what's needed. Keep on Supply - Some Boiler Stop Leak Powder or Chemical, just in case you discover a leak in the Winter... that should do it for you, good luck, and I hope that helps you my friend.....
