Tool Talk Discussion Forum
old Jeep HY LO hydraulic pump info
rod
03-09-2004 12:05:31
Hi all I picked up an old hydraulic pump it is belt driven was mounted on a Jeep has Jeep on it and HY Lo and Monarch Road Machinery Grand Rapids also has a control assembly on it I was told it was for a snow plow where could I find out what direction it is supposed to turn and maybe if parts are still made for it like seals etc seems real heavy built any info much appreciated.
regards
rod
Lloyd ( in CT)
03-10-2004 11:55:26
 Re: old Jeep HY LO hydraulic pump info in reply to rod, 03-09-2004 12:05:31
I have that pump on my 59' jeep truck,works like a champ,hardly leaks a drop-
Chip
03-10-2004 06:09:44
Monarch (Grand Rapids,Mi) is still in business. They build hyd pumps,power units,ect.Their units are used by many different companies.Western &Meyer both used them. Older units may or may not be rebuildable(depends on whats wrong)newer ones are more 'throw away'. Most all plows now are electric/hyd,but if you want belt drive,it can be done.Your pump should mtg to the gen,they added a pulley to it & turns the same as engine. As aside note saginaw (GM) ps pumps have also been used.A good hyd shop should be able to fix it.
RWK in WI
03-09-2004 17:11:23
We had one of these on a 57 CJ 5. It was piggy-back mounted to the generator on the curb side of the engine. It had a raise / lower control rod that ran back through the dash. If I remember right it worked real well and had plenty of lift. I may be mistaken but I think the plow that it lifted was a "Western" . So that might be a source of info on the pump also. I believe Monarch supplied pumps to many users.
rod
03-09-2004 17:17:10
 Re: Re: old Jeep HY LO hydraulic pump info in reply to RWK in WI, 03-09-2004 17:11:23
I found a pic of one mounted as you describe I think I will sell it don't see how it will fit my S 10 no room with a 4.3 I have a fisher plow real old snowcaster I think trying to make mounts for the old truck just to plow the driveway so live and learn
regards
rod
Brian G. NY
03-09-2004 15:40:46
The direction shouldn't be hard to figure out; just hold it as if it were mounted on the engine. When facing the front of the engine (and the pump), they should both turn clockwise. I would type in Monarch Road Machinery on "Google" and see what you come up with. BTW, I got a couple of these on a trade/deal afew years ago but I tucked them away and haven't even looked them over real good. Some day I'll get "a round tuit".
Matt V MI
01-04-2005 20:28:06
 Re: Re: old Jeep HY LO hydraulic pump info in reply to Brian G. NY, 03-09-2004 15:40:46
Hey Brian
Would you be interested in selling one of the pumps that you currently have? I have a 47 Willys Jeep and the pump on there broke. The pully and shaft snapped off.
Thanks,
Matt
tim
03-14-2004 12:28:49
Hi Brian,
Would you be willing to sell one of those Monarch pumps ?
My 51 Willys Jeep has one for the snow plow, but it finally got too old and loose this winter and is shot. I've been looking here in Minnesota, but haven't found one yet. Can you help me out ?
Thanks.....
