Fuel Mix, Homelite XL
John
06-18-2003 09:55:51
I bought this chainsaw used,
Homelite XL, "UT no. 104444"
"Ser. no. 780870600"
have no manuals. I don't know the year, has no safety devices, would guess '77 - '80. Anyone familar with the saw know the fuel mix ratio?
Thanks, John
John
07-04-2003 07:16:41
 Re: Fuel Mix, Homelite XL in reply to John, 06-18-2003 09:55:51
Found a manual, 16:1 regular oil, or 32:1 premium oil, so I guess everybodies right.
Unfortunatley the plastic oil tank has a leak in it, have to try some glue or permaseal on it. DOH!
Thanks for all the replies
john
BillW
07-17-2003 21:06:29
 Re: Re: Fuel Mix, Homelite XL in reply to John, 07-04-2003 07:16:41
iF THE 'LEAK' IS BECAUSE OF A SMALL ROUND HOLE NEAR THE TOP CORNER OF YOUR FUEL TANK... YOU ARE MISSING A RUBBER 'DUCK-BILLED' CHECK VALVE THAT LETS AIR IN AS THE FUEL IS SUCKED OUT.
Contact me if you can't find one.
wdTom
06-22-2003 14:40:27
I would start off with 16 to 1, if it fouls plugs or has other problems, maybe try a leaner mix. A 16 to 1 say will smoke some, is normal.
Ray,IN
06-20-2003 21:56:32
I have an XL,blue paint. 16/1 ratio is correct. A saw shop talked me into using 32/1 ratio. After about 15 minutes sawing the engine locked up. I removed the muffler and spark plug, sprayed freely with knocker loose and worked the sprocker nut back n forth gently until it freed up and shot in some pure 2 cycle oil. Started it up and went back to sawing. 20 minutes later-same thing. I repeated the procedure, emptied out the gas, refilled the saw with a 16/1 mixture and the saw is running today. I went back to the saw shop and complained. The guy said OH- sorry, I thought your saw was red, they are 32/1. Traded off the saw for a Hopkins & Allen Forehand 12 ga. yesterday matter of fact.
Paul Janke
06-20-2003 16:03:09
I have been told that the proper mix is determined by the oil rather than by the engine. I don't know if it's true, but that's the way I do with mine.
32 to 1 or 4 OZ/Gal
06-19-2003 06:29:45
Got one.
cannonball
06-19-2003 05:24:52
have a super XL..mix is 16 to 1...need to find out what is right the newer saws i have are 50 to 1..do a search on internet and see....have nice day may god bless
bob
06-19-2003 23:13:21
 Re: Re: Fuel Mix, Homelite XL in reply to cannonball, 06-19-2003 05:24:52
Older saws ran 16:1 that is 16 parts gasoline to 1 part oil or 8ozs. to one gallon. They did have a premium oil that you mixed 32:1 or 4 ozs. to gallon. Either one was ok, usually cheaper to run the premium. This was in 1972. Later they made saws to run 32:1. This was to compete with Stihl, who had for years been making their saws to run 40:1.
Frank M.
06-18-2003 17:49:01
The place I worked at back then sold Homelite. 32:1 is the recommended ratio. That's 4 oz. to a gal.
TimV
06-18-2003 10:18:08
Most of the XLs, Super XLs, Super 2s, etc. ran between 25:1 and 32:1. The "one little bottle per gallon" mixes are USUALLY 50:1. I'd use 1 1/2 per gallon, which should put you in the ballpark. We ran our Homelites (both XL and Super XL) at 32:1, but you can adjust it slightly downward if you want.
Greg Carberry
06-18-2003 10:17:47
32:1 is the proper ratio for this saw
Ben in KY
06-18-2003 10:03:17
Should work ok with the little bottles of oil per one gallons of gas mix, like runs in about all of the other little 2 stroke stuff. I have an old Homelite and I use the little bottles of Poulan oil with no ill effects.
wdTom
06-18-2003 18:05:19
 Re: Re: Fuel Mix, Homelite XL in reply to Ben in KY, 06-18-2003 10:03:17
I am not a homelite expert, have an XL-903, I think anyway, and it says on the say 16 to one. Have run it that way for years, since buying it used in 76 or 77. Cut about 8 cords a year with it and it has been a good say, a little ragged, but gets the job done. In a way I wish it would wear out so I could get a lighter newer saw.
jake
06-18-2003 19:56:58
 Re: Re: Re: Fuel Mix, Homelite XL in reply to wdTom, 06-18-2003 18:05:19
32 to 1, have a 1978 saw and the best I have used that 3.5 cubic in motor is a power house and still looks new. Keep pumping oil to the bar and it'll last forever.
