CEM mig welder
Drill
11-02-2002 18:22:23
I just aquired a used mig welder. The front panel says: CEM dual MIG 120 model MI A493555. Would like a manual or any other info on this welder. Did a search on Google, but couldn't find anything. Thanks for any help
Tom Forbes
01-27-2008 14:46:33
 Re: CEM mig welder in reply to Drill, 11-02-2002 18:22:23
ok guys found out where to get parts and manual.CEM is short for Cemont they make the welder and available at the Telford group from the UK.Heres a link to there page >Link
hope>Link this helps you out because I searched my a$$ off to find this out lol. Cheers!
RJRICARD
07-16-2006 11:58:33
IS your CEM mig hot at the tip when turned on or do you have to press the trigger???
Mine is hot at the stinger when turned on and the trigger just seems to work the wire feed.....Is this normal????? ???
Ralph Sims
09-07-2006 04:39:09
 Re: CEM mig welder in reply to RJRICARD, 07-16-2006 11:58:33
Hi all the trigger does is feed the wire and start the gas. I have had one of these welders for about 12years and haven't had a problem with it.
Philaswel
02-05-2005 15:38:18
I have also purchased a second hand CEM "DUE MIG" with no handbook. I found a small piece of information on the WEB. I guy said CEM are the same as SIP. I don"t know what that means yet but I will research.
Phil
nother user
05-11-2006 05:15:53
 Re: CEM mig welder in reply to Philaswel, 02-05-2005 15:38:18
Have a CEM MIG and instructions. Am actually looking for a source of replacement parts such as the hand piece, liner etc as mine have worn out.
As to being a SIP, they certainly look similar although the DM 120 is several years old.
ian crate
05-17-2007 05:54:21
 Re: CEM mig welder in reply to nother user, 05-11-2006 05:15:53
hi i have just bought a cem mig welder, could you please give me a copy of the instruction manual
yours sincerely ian crate
slow project
09-25-2006 04:56:57
i have just been given a cem mig is there any chance of getting a copy of the instruction book
ricardo
12-12-2003 17:39:02
hey i have a chance to buy one of these welders thats a year old for $300 canadian dollars, is it a good deal?
ricardo
12-12-2003 17:38:38
hey i have a chance to buy one of these welders thats a year old for 4300 canadian dollars, is it a good deal?
colum byrne
06-24-2003 07:02:17
Like you I also bought a CEM Dual Mig 120 without any manual. If you have any luck I would appreciate you passing on any info.
Perth, Wsetern Australia
